Crack in cylinder #2859489
12/13/20 05:09 PM
12/13/20 05:09 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Question, will a sleeve seal up a vertical crack? or is a sealant applied when sleeve installed? If so I won’t weld it up.
Re: Crack in cylinder [Re: cudaman1969] #2859499
12/13/20 05:18 PM
12/13/20 05:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sleeve will work.. had a couple of blocks done
wave
Re: Crack in cylinder [Re: MR_P_BODY] #2859504
12/13/20 05:33 PM
12/13/20 05:33 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
.001 press, liberal application of 640 loctite. This one had 3 of them.
Re: Crack in cylinder [Re: cudaman1969] #2859561
12/13/20 08:24 PM
12/13/20 08:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
The shop should use a good sleeve sealer on the sleeve but the block will determine if it will seal up the sleeve or not.
I've had one 400 Mopar block that was so thin (.032 to .015 due to core shift) on the cam side of the driver side of the block that it would not seal up after cracking the block there whiney We tried sleeving all four cylinders also, no luck. That block was junk shruggy
Due NOT weld it up down twocents
Re: Crack in cylinder [Re: Cab_Burge] #2859713
12/14/20 08:41 AM
12/14/20 08:41 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I have had really good luck when sleeving a block - never had one leak - but I also have the block ceramic sealed up at the diesel engine shop - not sure what the product is but they pump a ceramic slurry through the water jackets of the block after the sleeve is installed.
Re: Crack in cylinder [Re: DoubleD] #2859728
12/14/20 09:33 AM
12/14/20 09:33 AM
an8sec70cuda Offline
Yes, a sleeve should seal that up no problem.
I sleeved a 454 chevy that had a huge gaping hole in a cylinder wall. Used a .125" thick sleeve w/ around .0015" press fit and a lot of green Loctite. Heat the block, freeze the sleeve, and knock her home w/ an old shortened axle shaft. Still running good in an old tow truck.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Crack in cylinder [Re: DoubleD] #2859785
12/14/20 12:16 PM
12/14/20 12:16 PM
fredericksburg,va
fredericksburg,va
Would like to know what that sealer is
Re: Crack in cylinder [Re: cudaman1969] #2860088
12/14/20 10:54 PM
12/14/20 10:54 PM
birdtracker Offline
birdtracker  Offline
and the name and city of shop and a contact person. Birdtracker
Re: Crack in cylinder [Re: birdtracker] #2860470
12/15/20 08:45 PM
12/15/20 08:45 PM
birdtracker Offline
birdtracker  Offline
hoping to keep this topic at the top so doubled will reply. Birdtracker
Re: Crack in cylinder [Re: cudaman1969] #2860518
12/15/20 10:49 PM
12/15/20 10:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
B1maxx said it was 640 Locktite..I dont know the number but I will take his word.. I have had a
couple sleeved but didnt know the sealer
wave
Re: Crack in cylinder [Re: cudaman1969] #2860547
12/16/20 12:11 AM
12/16/20 12:11 AM
PA
Scully Offline
Scully  Offline
PA
I sleeved countless Chevy blocks back in the mid 70s in a shop I worked for and although I rarely do them these days in my own shop I still use the same procedure, .002" interference with Indian Head gasket sealer. Freeze the sleeve first then with a 1" thick aluminum plate a few good whacks a sledge and it's good.
Re: Crack in cylinder [Re: MR_P_BODY] #2860616
12/16/20 09:16 AM
12/16/20 09:16 AM
It's the green Loctite 640. That's what I always used and never had any issues...even w/ some I thought may end up leaking.
https://www.amazon.com/Loctite-37424-Strength-Retainer-6-milliliter/dp/B0002KKTIG
Like Scully said, Indian Head works great. I've seen them put in using a can of spray paint and that works too. I'm sure there's other stuff people have used successfully.
CHIP
Re: Crack in cylinder [Re: MR_P_BODY] #2860731
12/16/20 01:04 PM
12/16/20 01:04 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
wave
The 640 to me is just part of the installation not necessarily a sealer. An old timer told me a side benefit was filling of the microscopic voids (left after boring) to help in heat transfer out of the sleeve. I don't like freezing them they get frost on them prior to installing and I don't want all that water contaminating the 640.
