Best big block distributor, 7000 RPM + vacuum advance #2858423
12/11/20 10:40 AM
12/11/20 10:40 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Any kind, could be dual point + vacuum, could be electronic, could be what ?
I don't think I want to step up to coil-on-plug, not yet anyway.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: hemienvy] #2858539
12/11/20 02:04 PM
12/11/20 02:04 PM
moparx Offline
moparx  Offline
i'm interested in this as well, although i'm leaning toward a factory distributor with either a pertronix or gm HEI conversion, plus modified weight slots.
beer
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: hemienvy] #2858553
12/11/20 02:25 PM
12/11/20 02:25 PM
I've never used a vacuum advance on a drag race car, I have tried them on one of my street and strip car and didn't see any advantaged to using them on the street confused
I do recurve my distributors to start with so I have between 14 to 18 BTDC at 900 RPM idle and 33 to 36 degrees all in by 2000 RPM wrench up
I don't drive any of my street cars on any long distance trips of more than 30+ miles either though so maybe there might be a fuel mileage increase at constant speeds above 40 MPH using a vacuum advance shruggy
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: Cab_Burge] #2858560
12/11/20 02:33 PM
12/11/20 02:33 PM
moparx Offline
moparx  Offline
vacuum advance will help mileage a tad, and has no downside when going to the track.
Cab, i'm with you on the specs at idle and all in by 2000. up
like you always say : "test, test, and test some more !"
i'm also thinking of using the epoxy filled ford truck coil. [91 ish or so ? shruggy]
only airport drags around here any more, so there will be more street "play" than track.
beer
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: moparx] #2858576
12/11/20 03:16 PM
12/11/20 03:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I just run a rebuilt factory electronic with lightweight #925B Mr. Gasket springs hooked to MSD 6al and timing controller boxes.
You can get the nylon bushings for the bottom at Lowes if you rebuild one. The originals always crack when you push out the roll pin.
'63 Dodge 330
11.19 @ 121 mph
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: hemienvy] #2858580
12/11/20 03:29 PM
12/11/20 03:29 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: John_Kunkel] #2858599
12/11/20 04:13 PM
12/11/20 04:13 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Waay back in the day the Grump would set up his distributor with ever advancing springs to over 10,000 rpm. as the rpms went over 7000 the timing (with points) would start retarding (set 36 at 3000 at 7000 it was 33) why I don’t know maybe flex, coil slows down, ??? Maybe the electronic stuff handle it better now but imo it’s all about the fuel, good octane run full advance.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: John_Kunkel] #2858612
12/11/20 04:34 PM
12/11/20 04:34 PM
MN
W
Willie68coronet Offline
W
MN
I got one from O'Reilly's for electronic ignition and put a different connector on it for my Crane Hi-6. I took out the locked out tall billet firecore distributor because I wanted to try vacuum advance as well.
I took out the heavy springs and put one tiny spring in it so it has all the mechanical advance at idle and adjusted the canister to start advancing at 8 inches of vacuum and cruising at 70 with 15 inches ads about 15 degrees of timing.
With my updated cooling system and firecore distributor, my water temp was about 195-200 within 10-15 minutes at 70 mph on humid 95 degree day and a richer carb tune than was optimal (leaning it made it hotter). Then trying the vacuum advance in the same weather my 70 mph cruising water temp never got higher than 180-185 after 45 minutes and I was able to lean the carburetor down and not get the temp higher and make the engine run happier and cleaner, so I don't buy into the hate for vacuum advance on performance engines.
I had to clearance my EZ heads since the distributor is lower. The distributor has a metal bushing the roll pin goes through instead of nylon like a stock one and summit and jegs and firecore sell a hei style cap for it. I haven't had it up to 7000 yet but probably 6500 and the timing checks out whenever I put a light on it
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear
First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: hemienvy] #2858638
12/11/20 05:42 PM
12/11/20 05:42 PM
AndyF Offline
AndyF  Offline
Not a lot of choices for performance distributors with vacuum advance. These days I'm using digital control on my projects. The Holley stuff uses electronics to provide a full custom timing table including start retard, high speed retard, vacuum advance, temp dependent timing controls, boost retard, nitrous retard, etc.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: AndyF] #2858645
12/11/20 06:00 PM
12/11/20 06:00 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: 65Fury440] #2858653
12/11/20 06:19 PM
12/11/20 06:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Most recent purchase for a distributor as described by OP was a reworked unit from FBO.
Worked great, no problems.
Rest of the system is an MSD-6 and F150 epoxy coil.
Street strip deal, 512" RB that ran 11.30s with 3.23s & 275/60R15s.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: cudaman1969] #2858687
12/11/20 07:39 PM
12/11/20 07:39 PM
Washington
madscientist Offline
Washington
I’d have to go back and read what Jenkins said about why the curve kept going, but electronic ignitions are far worse for RPM retard than points.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: madscientist] #2858866
12/12/20 10:30 AM
12/12/20 10:30 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Let me know what you find out, just going by memory but that ain’t much nowadays.
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: cudaman1969] #2858894
12/12/20 11:42 AM
12/12/20 11:42 AM
Washington
Washington
LOL...I will...just gotta find my copy of his book first!!!
Re: Best big block distributor, 7000 RPM + vacuum advance [Re: madscientist] #2858910
12/12/20 12:10 PM
12/12/20 12:10 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I run these along with some friends on the street
Pretty sure these are Firecore sold by Jegs
I can adjust the mechanical advance with the distributor in the engine - Very easy
Quality so far so good
They come with a few sets of springs and adjustable vacuum advance
https://www.jegs.com/i/JEGS/555/40504/10002/-1
https://www.jegs.com/i/JEGS/555/405...amp;model=CHARGER&submodel=SUPER+BEE
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
