Indy Rockers #2857849
12/09/20 09:58 PM
12/09/20 09:58 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I’m running 1.6 Indy aluminum rockers on Indy -1 heads w a straight line performance solid roller cam. 266@.050, .667 w 1.6, and 112lsa. The spring pressure is 275 seat and 650 open. Not super aggressive as far as a race solid roller, but Ive heard the Indy brand rockers are not the go-to rockers for aggressive cam profiles. I’m hoping to hear some success stories to put my mind at ease smile ... Anyone care to share?
2 kids and a dog
Re: Indy Rockers [Re: TonyS451] #2857877
12/09/20 11:00 PM
12/09/20 11:00 PM
South Dakota
dakotahotrodder Offline
South Dakota
I had them on my 451 until I broke a rocker and screwed a bunch of stuff up. Rebuilt the engine and put Harland Sharp 1.5 rockers on. I decided to put a new set of Indy 1.6 rockers back on to see if there was any performance gain, and there was about a tenth, until I broke another rocker a couple years later. I am running a comp solid roller .660/.663 lift with 1.5 rockers. I don't remember off hand what spring pressures are, but similar I'm sure.
Re: Indy Rockers [Re: dakotahotrodder] #2857915
12/10/20 12:52 AM
12/10/20 12:52 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
The Dove rockers are weak, step up to HS or T&D, much cheaper to do it before its a problem, because it'll be an expensive problem.
Re: Indy Rockers [Re: rebel] #2857947
12/10/20 07:36 AM
12/10/20 07:36 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Dove used to make the rockers for INDY. Dove is no longer in business, and hasn't been for quite some time now. Those rockers were OK to use with a flat tappet cam, but not for a solid roller. I can't complain, as I got 20+ years out of mine, but they have gotten to the point of not worth taking the risk.
69 GTX 68 Road Runner
Re: Indy Rockers [Re: JERICOGTX] #2858003
12/10/20 10:34 AM
12/10/20 10:34 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Using them with a roller is just asking for unhappiness.
If you google “broken Indy rocker arm”, there is no shortage of results.
Re: Indy Rockers [Re: TonyS451] #2858010
12/10/20 10:45 AM
12/10/20 10:45 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
5 years of bracket racing on my Indy 1.6 (360-1) rockers on my 422 engine. .660 lift solid lifter cam shifted at 7000rpm. Engine will be getting a set of T&D rockers I bought from a Moparts member this Winter when I rebuild everything.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Indy Rockers [Re: TonyS451] #2858013
12/10/20 10:53 AM
12/10/20 10:53 AM
gregsdart Offline
gregsdart  Offline
Those rockers have a bad rep when pushed hard. I agree time to upgrade. In the mean time if you want to chance it, run the lash tighter to give them a fighting chance. By tighter i am thinking .005 to .010 depending on the original setting.
Re: Indy Rockers [Re: gregsdart] #2858026
12/10/20 11:42 AM
12/10/20 11:42 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I ran the Indy -1 1.5 rockers for over 600 passes with a 278@.050, .660 roller. Found 2 with a crack at the body holding the roller axle. They had a crack on one side only. Then installed Indy 1.6, .705 lift. Never hurt one. They were on the car when I sold it.
Doug
Re: Indy Rockers [Re: dvw] #2858069
12/10/20 01:01 PM
12/10/20 01:01 PM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Doug
I had the same results with the 1.5's on the same cam. Mine were in the car for ten years. Sitting in a box on the shelf now. I went with Harland Sharps the second time around.
Decent rockers with a mild cam. Out of production now though.
Re: Indy Rockers [Re: sixpakdodge] #2858206
12/10/20 06:52 PM
12/10/20 06:52 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
I appreciate the feedback. I figured there might be some success stories, and also not.. Like the 8 3/4
Since I have zero passes and maybe 200 street miles on the engine, Ill probably keep them for now. But I'll be thinking seriously about that upgrade once I start making some passes.
2 kids and a dog
Re: Indy Rockers [Re: TonyS451] #2858211
12/10/20 07:05 PM
12/10/20 07:05 PM
PA.
"Little"John
"Little"John
PA.
Just blue up your valve tips and make sure your rocker geometry is correct. Lots of guys throw them on and go never checking things over. I see some ugly stuff at the track.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Indy Rockers [Re: TonyS451] #2860125
12/15/20 12:35 AM
12/15/20 12:35 AM
WI
mopar873 Offline
mopar873  Offline
WI
Hello,
I had some bad experiences with them running a Comp RX316R-8 roller, but that cam is fairly rowdy. Valvetrain maintenance on that engine was constant. I personally wouldn't use them for anything with spring pressures higher than what a solid flat tappet would use.
