Drum brake mounted to hub issue... #2857385
12/08/20 10:37 PM
12/08/20 10:37 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Ok, guys!
I have a weird problem, on my 1966 Dodge Coronet 440.
My drum brakes on the front passenger side let loose and ruined my brake drum.
It left some horrible scars that can't be rubbed (turned) out.
I would like to only swap out the brake drum, but it is mounted to the hub.
This is different from the driver's side front.
Is there any way to separate the drum from the hub?
Let me know.
Thanks!
Tim...
"Robots building robots.... now that's just stupid!" - Will Smith in the movie "I, Robot".
'71 Demon (340/727)/'69 Charger (383/727)/'65 Barracuda (273-2V/904)/'66 Coronet (340/727)/'86 Dodge Aries (2.5L)/'78 Dodge Aspen (318-2V/904)
Re: Drum brake mounted to hub issue... [Re: cuda_tim] #2857400
12/08/20 11:05 PM
12/08/20 11:05 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Sure. Use a swedge cutter to cut the swedge on the studs and then just tap it out. I made some swedge cutters and still have some extras if you have interest.
Re: Drum brake mounted to hub issue... [Re: markz528] #2857412
12/08/20 11:38 PM
12/08/20 11:38 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Thanks!
So do I have to replace the studs or does it only cut the swedge around the bottom of the stud?
Can you PM me? Maybe we can make a deal.
Re: Drum brake mounted to hub issue... [Re: cuda_tim] #2857416
12/09/20 12:00 AM
12/09/20 12:00 AM
AndyF Online content
AndyF  Online Content
I have a pair of hubs with good drums if you want to replace the whole assembly.
Re: Drum brake mounted to hub issue... [Re: AndyF] #2857487
12/09/20 07:43 AM
12/09/20 07:43 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can cut the swedge with an 11/16 hole saw with the center bit removed. Cut thru the drum only.
Doug
Re: Drum brake mounted to hub issue... [Re: AndyF] #2857617
12/09/20 02:05 PM
12/09/20 02:05 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Hey AndyF.... I'll keep that in mind! Thanks!
Re: Drum brake mounted to hub issue... [Re: dvw] #2857619
12/09/20 02:07 PM
12/09/20 02:07 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Hey Doug... Interesting.... Not sure how you would remove the center bit. But seems like that would work. Thanks!
Re: Drum brake mounted to hub issue... [Re: cuda_tim] #2857632
12/09/20 02:41 PM
12/09/20 02:41 PM
moparx Offline
moparx  Offline
most quality hole saws use a separate mandrel with a removable 1/4" drill bit that is held in with a set screw.
some single name brand hole saws without the mandrel have removable bits as well, but not all do.
if you buy one for this, keep in mind about the removable bit, but also make sure the saw you buy is deep enough for the length of the lug stud.
beer
Re: Drum brake mounted to hub issue... [Re: dvw] #2857662
12/09/20 03:17 PM
12/09/20 03:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Doug
Re: Drum brake mounted to hub issue... [Re: John_Kunkel] #2857698
12/09/20 04:20 PM
12/09/20 04:20 PM
Waynesboro, PA
cuda_tim Offline OP
cuda_tim  Offline OP
Waynesboro, PA
Nice pix!
