Re: Take a ride 5.15 at 132
[Re: bonefish]
#2856418
12/07/20 09:50 AM
12/07/20 09:50 AM
Posts: 34,883 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Looks like it pulls really hard in first 100 feet .. good job !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: dvw]
#2856471
12/07/20 11:34 AM
12/07/20 11:34 AM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
T I love the sound. Couldnt see the tach through your face shield. .What rpm? Doug This would be the race pack from that pass
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: WHITEDART]
#2856500
12/07/20 12:23 PM
12/07/20 12:23 PM
Posts: 4,675 On the parachute mount
n20mstr
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block,
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2856520
12/07/20 01:03 PM
12/07/20 01:03 PM
WHITEDART
bean town ....Ca
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block, .. yes we run a dump valve in the trans the converter is still a tick tight this is a brand new combination for us.. . I think if we can ramp the timing in quicker there is some ET left on the table.. just looking at the data in first gear alone there is a bunch..
[Re: WHITEDART]
#2856553
12/07/20 01:56 PM
12/07/20 01:56 PM
n20mstr
You have a dump valve? are you opening it at the shifts? seems to drop a lot of rpm at each shift Thats some high rpm too....close to 10?? Nice pan vac Impressive for sure all motor small block, .. yes we run a dump valve in the trans the converter is still a tick tight this is a brand new combination for us.. . I think if we can ramp the timing in quicker there is some ET left on the table.. just looking at the data in first gear alone there is a bunch.. Sure for ET, if you can push that RPM up after the converter grabs , you will pick up 330 et. That and open the dump valve on the 2-3 shift to get the RPM up so it doesnt take so long to recover. But im rambling here, you know what you doing. Looks like a lot of potential
[Re: n20mstr]
#2856575
12/07/20 02:27 PM
12/07/20 02:27 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Mighty impressive. If the air had been 1200-1500 feet it may have run an 0’
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
