Jetting questions
#2856160
12/06/20 05:51 PM
12/06/20 05:51 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Here's something i would like to ask about 2 different combos requiring different jetting: Doms 470 requires more jet than my 511, why? Dom's 470 with RPM's ported, 12:1 compression, solid roller 274/280@50-.440/.427LL on 108- 61* overlap, M1 t ram, same 650 carbs as mine(1.325 venturi) 82 jet squared fenderwell header. My 511 with E MW ported, 12.5:1, SFT 270/276@50-.403/.410LL on 110-53* overlap, Indy T ram, same carbs as Dom 650(1.325 venturi) 78 jet squared , inframe headers. I would think the bigger cube higher compression motor would want more fuel, not the case. Can anyone explain why? Dom sees mid 12's on wideband in 66* weather and i see mid 13's in 50* weather WOT. My jetting should be close when the warm summer weather comes back here in Michigan and would expect 13 O range WOT.
Re: Jetting questions
[Re: mopar dave]
#2856176
12/06/20 06:42 PM
12/06/20 06:42 PM
Posts: 287 PA
Harry's Taxi 2
PA
Maybe your larger engine has a stronger pull on the fuel through the boosters.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: mopar dave]
#2856540
12/07/20 01:40 PM
12/07/20 01:40 PM
Thumperdart
State of confusion
And like we spoke the other day, your manifold is a v-bath all sharing the same open area and my M-1 is a flat base manifold with minimal cross plenum up high for comparison almost making mine like the old IR manifolds acting more like 2 separate carbs requiring a damn near single carb tune x2. My tune now is actually more like two individual 750's as far as ifr's and jetting are concerned as opposed to dropping those down significantly like yours are tuned now however, I'm all ears here and would love other opinions cos the learning game never stops till you close the door......Remember too, I'm at 3500+ feet and run VP-101 Oxy fuel needing a richer mixture than as well and you are damn near sea lever so you would THINK i would need even less jet but not the case and why we always hear, "No two motors are the same even if built with similar components and compression...
[Re: Thumperdart]
#2856557
12/07/20 01:58 PM
12/07/20 01:58 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Many things affect the tune a carb needs, dom touched on a few. One he mentioned that I think often gets overlooked or is misunderstood is elevation, and as far as a carb is concerned it can be a BIG one. The higher up you go in elevation the lower the barometric pressure/air density becomes. For instance Vegas a great barometer is 28.00,(actual readings not the corrected ones used by your local weather man) in the midwest 29.5 is a typical good day. The lower barometer reading will require less jetting to achieve the same AFR's or tune. Not to mention the myriad of internal engine varibale that can effect the engines actual pull on the booster itself, the harder it pulls on the booster the less jet it will need in theory and vice versa.
[Re: mopar dave]
#2856628
12/07/20 03:43 PM
12/07/20 03:43 PM
Posts: 304 Florida
Mark Whitener
Distribution and runner velocity are a big part of it. An engine that does both better will atomize, vaporize, and distribute better requiring less overall fuel. Then you add fuel variations, weather variation s in DA, it can be significant. Even a cam change can make a significant difference in jetting needs.
Mark Whitener [url=www.racingfuelsystems.com[/url]
