Home generator question
#2855735
12/05/20 03:05 PM
12/05/20 03:05 PM
Posts: 5,807 ohio
ruderunner
ohio
after losing power for 3 days twice in the last month, I'm looking at setting up a more permanent generator arrangement than I've been using.
I'm thinking of wiring in a separate system to run a few essential items. Never the twain shall meet. For various reasons it's impractical to do what most do and backfeed through a heavy duty outlet.
My questions are about grounding. I'm aware that you can use the existing ground buss but should you? Does it have a negative impact on the generator?
Secondly, I'll be installing a separate breaker box and obviously it's ground buss will connect to the ground on the generator. Should I also tie into the existing house ground or add a dedicated ground for the generator system (it wouldn't be a big deal to do a second ground rod)
Angry white pureblood male
Re: Home generator question
[Re: ruderunner]
#2855792
12/05/20 06:47 PM
12/05/20 06:47 PM
Posts: 25,784 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Best way to do it is to run the generator through a transfer switch, the switch wires to selected breakers in your main panel and the switch is fed by a large single cord. Individual switches on the transfer switch select between your utility power and the generator power. The transfer switch wires to your ground buss and it's recommended to also ground the generator.
My installation has a 6-circuit transfer switch but you can get them with more circuits. I didn't ground the generator and that doesn't affect its operation.
[Re: John_Kunkel]
#2855797
12/05/20 07:07 PM
12/05/20 07:07 PM
Posts: 5,807 ohio
ruderunner
ohio
One of the problems is connecting to the main panel. There's no easy way to access it from outside the house. Not to mention that getting the generator near the main would be impossible in the winter with snow on the ground.
That doesn't include the fact that the main is diagonally opposite the garage and most of the stuff I want to run. I keep the generator under the lean to for weather protection and ventilation, that puts it about 85 wire feet from the main breaker, and then the items to run are about 75 wire feet from the breaker.
Or, I add a dedicated system to run everything desired within a 20 foot distance.
That said, it looks like I'll be adding a ground rod, thanks.
[Re: 5thAve]
#2855895
12/06/20 02:51 AM
12/06/20 02:51 AM
Posts: 5,807 ohio
ruderunner
ohio
Yeah, that's pretty much it. It can be done of course but then it's a lot of heavy wire run from opposite corners of the house, hence a separate system.
Street power comes in to the SW corner of the house (meter andpanel location), the well pump, water heater and furnace are in the NE corner of the basement. The attached garage is the E end of the house and the lean to is on the N wall of that. I can literally touch the water heater and the door to the lean to at the same time.
Besides those items, we'll be setting up 1 outlet in the kitchen (next to the garage) and maybe 1 in each bedroom for a lamp. Basically just the essentials. I'm thinking twist lock cords for the basement items to connect to the 2 systems and putting the extra panel next to the man door for selecting which items are powered at any moment.
[Re: ruderunner]
#2855960
12/06/20 11:58 AM
12/06/20 11:58 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
[Re: 360view]
#2856141
12/06/20 04:52 PM
12/06/20 04:52 PM
Posts: 20,762 A collage of whims
topside
A collage of whims
I had an electrician install a panel & switch in the main house panel, got a HF 9000W generator, and put it to the test. Works fine, runs my gas heat & appliances. Oddly, my place runs the well and 1 shop from the main feed from the road, so if power goes out they don't work. Not a big deal, I keep extra water: 5 gal for toilet, gallons for drinking & etc. Even after building a screened enclosure, grounding & hook-up cord, I'm in the project under $1,000. Sits on my back deck under a carport, only place it can avoid snow. To know when power returns, I run a trouble light from the back shop & switch it on.
[Re: Powerflow]
#2856380
12/07/20 06:43 AM
12/07/20 06:43 AM
Posts: 5,807 ohio
ruderunner
ohio
Just be careful that whatever you do doesn't create a back-feed hazard where you're pumping generator power into the utility line coming to your house. Linemen have been hurt and killed when they contact the back-fed line that was supposed to be dead. Not to mention it would destroy the generator. This is intended to be an isolated system.
[Re: ruderunner]
#2856524
12/07/20 01:15 PM
12/07/20 01:15 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Just be careful that whatever you do doesn't create a back-feed hazard where you're pumping generator power into the utility line coming to your house. Linemen have been hurt and killed when they contact the back-fed line that was supposed to be dead. Not to mention it would destroy the generator. This is intended to be an isolated system. Let me make sure everyone understands the danger there, when the home generator backs feeds the damaged utility lines at 120v?, when that power reaches the first utility transformer, it can get stepped up to from 5,000 to 22,000 Volts or higher, and that can sure hurt a lineman, or a kid playing in a water puddle with a nearby hanging powerline, that was "off" minutes earlier. Additionally, everyone wants the workers to get their power back on as quickly as possible after a storm, but it only takes one careless homeowner to energize a whole neighborhoods damaged power grid, and the workers have no idea who the jerk is, so don't be one.
[Re: Powerflow]
#2856525
12/07/20 01:18 PM
12/07/20 01:18 PM
John_Kunkel
Rio Linda, CA
At the end of that video I wonder why he turns off the main breaker to use the transfer switch. The transfer switch will isolate the circuits and prevent any feedback. If there isn't a disconnect between the incoming electricity from the meter to the transfer switch, the transfer switch needs to be Service Entrance rated, which has a built-in circuit breaker to interrupt the power coming in from the meter. The transfer switch used in the video has individual breakers for each circuit and the switches isolate the service.
[Re: DrCharles]
#2856671
12/07/20 05:10 PM
12/07/20 05:10 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Square D (Schneider), Eaton (Type BR) are the only two so far that I have used and both are UL listed and meet NEC article 702. I think Cutler Hammer also has one with a factory dead front cover preinstalled.
11B40
