Lifters #2855319
12/04/20 04:21 PM
12/04/20 04:21 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Ok I know one can use solids on a hydraulic cam but what are the problems of using hydraulic lifters on a solid cam?
Re: Lifters [Re: cudaman1969] #2855377
12/04/20 06:35 PM
12/04/20 06:35 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The ramp on a solid is different than a hydro, the seat duration would be much more & depending on the cam the valves would not be closed when they should.
Re: Lifters [Re: cudaman1969] #2855389
12/04/20 06:56 PM
12/04/20 06:56 PM
Idaho
LaRoy Engines Offline
Idaho
In an emergency when I tried that on a street solid roller in the shop truck I ended up with rougher idle (increased overlap?) but it still drove around okay. Never did test it on my dyno so I cannot speak to power curve changes.
