Leaf Spring slider Tech #2853573
11/30/20 09:45 PM
11/30/20 09:45 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Time to try something new...looking to improve the 60 ft of the car substantially... these are manufactured by LP racing... the current sliders are bolt in so I can always go back if things do not play nicely
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Leaf Spring slider Tech [Re: WHITEDART] #2853615
11/30/20 11:24 PM
11/30/20 11:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I guess they are supposed to allow more body separation? Post video when you make some passer.
Re: Leaf Spring slider Tech [Re: justinp61] #2853634
12/01/20 12:12 AM
12/01/20 12:12 AM
florida dade
cesar perez Offline
cesar perez  Offline
florida dade
Will inprove
Re: Leaf Spring slider Tech [Re: WHITEDART] #2853669
12/01/20 08:14 AM
12/01/20 08:14 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Pretty Flippin Pricy for what they are selling!
A couple waterjet welded steel plates with a cam slot, Just Wow $440
Re: Leaf Spring slider Tech [Re: RATTRAP] #2854375
12/02/20 02:32 PM
12/02/20 02:32 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
thats crazy , i would imagine thats really going to stand up the back of the car. Looking forward to how it works.
....BAD A$$ STREET CAR.....
Re: Leaf Spring slider Tech [Re: n20mstr] #2854446
12/02/20 05:22 PM
12/02/20 05:22 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
not a fan of that design.
JAKES AUTOMOTIVE
Re: Leaf Spring slider Tech [Re: WHITEDART] #2854514
12/02/20 07:33 PM
12/02/20 07:33 PM
VA Beach, VA
Runnoft Offline
Runnoft  Offline
VA Beach, VA
I've seen a couple of people try them out somewhat successfully although I'm not convinced they are better than a conventional slider. Tom Barton had them on Nova here on the east coast that runs 4.40's in the eighth and ended up going back to the 10 degree slider. Armen Maghdessian had them on his car in Vegas two weeks ago and they worked great BUT that track was so tight everyone was going personal best 60's. Regardless, I don't think they are an easy bolt on and forget it part - the shock tuning is going to be critical to making the whole thing work. The other thing is - the cars trying to use these are probably 2000+ horsepower combos or close to it. I run leafs and have been in the 1.0 sixty range probably 10 times and have run a 1.06 sixty three times. That's my best so far and I use a 10 degree slider set up. I like the out-of-the-box thinking behind these for sure.
Cruiser: 66 Dodge Coronet 500, Indy SR 440, Gen 7 Accel EFI = 11.38 @ 116.
Racing: Brand X, X275 Procharged Smallblock on M1, Leafsprings, Holley EFI = 4.30 @ 168
Re: Leaf Spring slider Tech [Re: Runnoft] #2854552
12/02/20 08:53 PM
12/02/20 08:53 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
At least the tires should be easier to get off the car.
Re: Leaf Spring slider Tech [Re: n20mstr] #2854623
12/02/20 11:58 PM
12/02/20 11:58 PM
bean town ....Ca
W
W
bean town ....Ca
Hopefully I will have good information to report back I just didn't feel I could sit here without trying it...
Re: Leaf Spring slider Tech [Re: Runnoft] #2854624
12/03/20 12:09 AM
12/03/20 12:09 AM
bean town ....Ca
W
W
bean town ....Ca
. Just looking for a little more rear travel.. figured it would be worth a try... definitely some challenges ahead. Hopefully a quality science experiment
Re: Leaf Spring slider Tech [Re: justinp61] #2854625
12/03/20 12:10 AM
12/03/20 12:10 AM
bean town ....Ca
W
W
bean town ....Ca
.. I can only hope it's almost impossible to get the tires off now
Re: Leaf Spring slider Tech [Re: n20mstr] #2854626
12/03/20 12:13 AM
12/03/20 12:13 AM
bean town ....Ca
W
W
bean town ....Ca
. Controlling the hit has been the challenge... if I can get the timing and sooner without running out of rear travel I can see positive results and this song but by but absolutely no it's only going to be a learning curve
Re: Leaf Spring slider Tech [Re: RATTRAP] #2854742
12/03/20 11:29 AM
12/03/20 11:29 AM
New York
polyspheric Offline
polyspheric  Offline
New York
That price is their R&D cost
Boffin Emeritus
Re: Leaf Spring slider Tech [Re: WHITEDART] #2854756
12/03/20 12:13 PM
12/03/20 12:13 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car.
JAKES AUTOMOTIVE
Re: Leaf Spring slider Tech [Re: polyspheric] #2854795
12/03/20 01:35 PM
12/03/20 01:35 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
We the customers are thier R&D product testors.
Re: Leaf Spring slider Tech [Re: JAKE68] #2854882
12/03/20 05:44 PM
12/03/20 05:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
don't know why you would want more travel. That is not the most desirable action you want. we usually stiffen the shocks to control that. you want it to pitch and rotate. With that set up you drive the ic way up. what kind of power you making if your sixties are 1.06. that is faster than an ss/ah car. [/quote]
This is a Pro Radial style tire. If you can separate the housing further you can keep adding load to the tire. And you have a shock with the ability to control the speed at which this happens, my bet is you can ramp in power earlier.
Doug
Re: Leaf Spring slider Tech [Re: dvw] #2854899
12/03/20 07:08 PM
12/03/20 07:08 PM
N
n20mstr Offline
n20mstr  Offline
N
Doug [/quote]
It will be interesting to see if this slider shows up on other radial tire cars. THe ability to have a "moving" IC is very helpful, As the Fox body mustang has
Re: Leaf Spring slider Tech [Re: RATTRAP] #2854919
12/03/20 08:05 PM
12/03/20 08:05 PM
New York
polyspheric Offline
polyspheric  Offline
New York
So what you're buying is one shot from the sketch on the cocktail napkin straight to the welder with no testing?
Boffin Emeritus
Re: Leaf Spring slider Tech [Re: dvw] #2854929
12/03/20 08:29 PM
12/03/20 08:29 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Doug
This was my exact thoughts as well Doug, that this setup was only intended for cars that are ramping in timing and power well after the initial hit. I'm not familiar with OPs car, so hopefully that's what he's doing.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Leaf Spring slider Tech [Re: dvw] #2854978
12/03/20 09:54 PM
12/03/20 09:54 PM
bean town ....Ca
W
W
bean town ....Ca
Doug [/quote]
1.15. Is our best so far . And yes it is a tick faster then in SSHA car.. naturally aspirated small block on a 28-10.5 Tire
we do not want to pitch rotate in radial tire trim..
