Can I modify my early 4500 carb to air bleeds #2854428
12/02/20 04:17 PM
12/02/20 04:17 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
I am rebuilding my 4500 series carburetor. My question is there enough of material around and under it to install a later style bleeder screw. These are the two up on the top of the carb.
Thank you...Ted
Re: Can I modify my early 4500 carb to air bleeds [Re: DusTed74] #2854455
12/02/20 05:49 PM
12/02/20 05:49 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Tap the holes that are on the metering block mating surface. High speed bleeds are direct tapped, idle bleeds are drilled, tapped and counter sunk. Search YouTube, there’s a video on it.
Re: Can I modify my early 4500 carb to air bleeds [Re: Leigh] #2854474
12/02/20 06:47 PM
12/02/20 06:47 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Or you could just drill and tap for 8-32, but only tap three or four threads deep.
Then just use brass 1/8" long setscrews and drill them yourself to the desired size. You can get 50 or 100 from McMaster-Carr for the price of one pretty air bleed, and not even have to countersink the hole scope
Worked fine on my 4780 carb, anyhow. wrench
Re: Can I modify my early 4500 carb to air bleeds [Re: Leigh] #2854529
12/02/20 08:21 PM
12/02/20 08:21 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
https://youtu.be/OkOTQCgpfK8
Re: Can I modify my early 4500 carb to air bleeds [Re: Leigh] #2854855
12/03/20 04:11 PM
12/03/20 04:11 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Sure can. 8-32 set screw.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Can I modify my early 4500 carb to air bleeds [Re: 68 HEMI GTS] #2854857
12/03/20 04:17 PM
12/03/20 04:17 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I did my first one a couple of years before the “HP” 4500’s came out.
If you wanted adjustable air bleeds in a 4500...... you had to modify a stock body.
Re: Can I modify my early 4500 carb to air bleeds [Re: fast68plymouth] #2854914
12/03/20 07:45 PM
12/03/20 07:45 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
Man that carb looks great. What type of screw did you use on this?
Thanks.
Re: Can I modify my early 4500 carb to air bleeds [Re: DusTed74] #2855035
12/03/20 11:37 PM
12/03/20 11:37 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Thanks.
8-32 x 3/32 brass set screw. They work and look great. Just drill to desired size with numbered drill bits.
Re: Can I modify my early 4500 carb to air bleeds [Re: 68 HEMI GTS] #2855267
12/04/20 02:42 PM
12/04/20 02:42 PM
WI. U.S.A.
DusTed74 Offline OP
DusTed74  Offline OP
WI. U.S.A.
Thank you. Ted
Re: Can I modify my early 4500 carb to air bleeds [Re: DusTed74] #2856641
12/07/20 03:53 PM
12/07/20 03:53 PM
Mark Whitener Offline
Yes, I do all the come thru my hands, plenty of material to tap 10-32, the outer two are fine with set screws. If you want to use regular bleeds you have to offset mill the hole before tapping to allow enough room for the heads. Otherwise you can use headed bleeds in one of the two, setscrews in the other. On two circuit conversions I may do that and just plug the outside with a set screw. 10-32 x 3/16 brass from McMaster-Carr, tap 5.5 turns with a bottoming tap you can also get from McMaster. I use a spiral flute tap, they eject the material better.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: Can I modify my early 4500 carb to air bleeds [Re: Mark Whitener] #2857131
12/08/20 03:32 PM
12/08/20 03:32 PM
moparx Offline
moparx  Offline
when tapping small holes in cast items like carb bodies, especially shallow threads, i like to use form [roll] taps.
there is less chance of making the threads oversize with that type of tap. those are also available at mcmaster as well as other places.
however, these taps require a [slightly] larger hole than cut taps, so check a chart to make sure you use the correct size drill.
beer
