Anti-freeze turned brown #2853292
11/30/20 12:05 PM
11/30/20 12:05 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Fresh motor, iron block and heads, stock radiator. Anti-freeze put in, cam broke in. Took car around the block and parked it. 6 months later (or maybe immediately) the stuff is the color of strong strong coffee. Never seen that before? This is not rust colored at all. As I said, looks like coffee, real strong coffee.
Any ideas? Seems to test for -35 ok.
Re: Anti-freeze turned brown [Re: SportF] #2853300
11/30/20 12:29 PM
11/30/20 12:29 PM
Md.
carnut68 Offline
carnut68  Offline
Md.
Did you use staight anti freeze or a mix? I noticed with anti freeze and tap water it always turned dirty. Started using distilled water and it was much better looking.
America First!
Re: Anti-freeze turned brown [Re: carnut68] #2853303
11/30/20 12:31 PM
11/30/20 12:31 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
I used tap water. Well, its from our well. But, never had this happen before when using tap water. 50% is what you gotta use here in Minnesota.
I could say it "can" get cold here. But I should say, it "does" get cold here.
Re: Anti-freeze turned brown [Re: SportF] #2853305
11/30/20 12:37 PM
11/30/20 12:37 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I still would think it's rust even though it doesn't look rusty. Mine turned rusty right after break-in. The block had been sitting for years prior to being installed. I really should drain the system and fill it with EvapoRust, bring the engine up to temp and let it cool down over night. Then drain everything and re-fill.
Re: Anti-freeze turned brown [Re: SportF] #2853306
11/30/20 12:37 PM
11/30/20 12:37 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Take a sample to a heavy equipment dealer (Cat for example) and have them run an acidity on the antifreeze. That happened to me once and it turned out to be a leaking head gasket.
Re: Anti-freeze turned brown [Re: SportF] #2853402
11/30/20 03:35 PM
11/30/20 03:35 PM
Ohio
3404 Offline
3404  Offline
Ohio
Sounds like it could be a head gasket.
Re: Anti-freeze turned brown [Re: 3404] #2853448
11/30/20 04:43 PM
11/30/20 04:43 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Pulled all the plugs and they look good. Plus, when it was running it didn't blow through the radiator.
Now, in better light, it looks dark dark green in the milk storage jug its setting in.
Re: Anti-freeze turned brown [Re: SportF] #2853470
11/30/20 05:39 PM
11/30/20 05:39 PM
North Dakota
North Dakota
I'd still have it checked. The way I found out I was in trouble was when the core plug heater started leaking. When I drained the antifreeze I thought something was amiss and when I found that almost all of the heater metal part on the coolant side had been eaten I knew I was in trouble. whistling
Re: Anti-freeze turned brown [Re: 6PakBee] #2853552
11/30/20 08:37 PM
11/30/20 08:37 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Do a simple flush first ( youtube Chris fixx coolant flush), I know its fresh, but follow the way he does it. Use distilled water, not your wells'.
If its still acting up, have it tested or get yourself a combustible gas tester as mentioned before.
If its a head gasket, doing a simple compression test should answer that
Re: Anti-freeze turned brown [Re: moparjim79] #2853567
11/30/20 09:31 PM
11/30/20 09:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I'll agrees with the first two suggestions, but not the third. if it's leaking bad enough to show up on a compression test there wouldn't be a question or need for the first two as it would be pretty obvious due to loss of coolant, overheating, missing etc.
beer
Re: Anti-freeze turned brown [Re: TJP] #2853569
11/30/20 09:38 PM
11/30/20 09:38 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
beer
I disagree, there's head gaskets that catastrophically fail and ones that fail but only act up when full operating temp is reached, repeating this many times when brought to temp but not bucking/carrying on for quite a while, then it $hits the bed all together. Heres another kinda easy test, put a borescope down the plug tube and tell us what the piston tops look like.
Keeping in mind now, 1 of your 3 criteria is already met.
Re: Anti-freeze turned brown [Re: moparjim79] #2853596
11/30/20 10:31 PM
11/30/20 10:31 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Well, here is what is wrong with the head gasket theory, it isn't blowing bubbles in the radiator.
Re: Anti-freeze turned brown [Re: SportF] #2853618
11/30/20 11:26 PM
11/30/20 11:26 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
That doesn't always happen. Thats why I made mention of the test kit
Re: Anti-freeze turned brown [Re: moparjim79] #2853664
12/01/20 07:58 AM
12/01/20 07:58 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
When working as a dealer tech I changed brown nasty coolant many times. Flush well and replace. That fixes it. There is nothing the matter with the head gaskets.
Doug
Re: Anti-freeze turned brown [Re: dvw] #2853710
12/01/20 10:06 AM
12/01/20 10:06 AM
RWG75
RWG75
Run it for several heat cycles, check the bottom of your overflow jug for sediment. If it's rust from the iron block, there will be a layer of silt in the jug [eventually]. One of my 440s does it and I recall more silt when changing a block freeze plug. A/F is much more green than brown. When it starts getting too dark, I back flush it with the block plugs out and clean the jug then start again.
Re: Anti-freeze turned brown [Re: dvw] #2853755
12/01/20 11:56 AM
12/01/20 11:56 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Doug
x2
Mo' Farts
Moderated by "tbagger".
Re: Anti-freeze turned brown [Re: Grizzly] #2853811
12/01/20 02:48 PM
12/01/20 02:48 PM
moparx Offline
moparx  Offline
i have had several engines over the years that had the "factory fill" coolant turn a nasty "poop" color, and it took several flushes over a couple month time period to clean it up so it would remain a clean, green color.
also, i'm not a fan of the new style "pre mixed" stuff. some of that can turn color when mixed with any residual coolant left in the system.
GM dexcool is the worst of the worst, and should be avoided at ALL costs !
as already been mentioned, use distilled water with a QUALITY coolant, but you may have to flush a couple of times to get it to stay clean.
i am also leaning toward a coolant filter plumbed into a radiator hose, but i haven't pulled the trigger on one yet.
beer
Re: Anti-freeze turned brown [Re: moparjim79] #2854042
12/01/20 09:57 PM
12/01/20 09:57 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
Please explain how
Quote
is going to show up on a compression test ?
shruggy
Re: Anti-freeze turned brown [Re: TJP] #2854056
12/01/20 10:23 PM
12/01/20 10:23 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
What are the different types of compression tests? Thats why I brought this up. Also, to be clear, a compression test is not the end all. A leak down test should probably be performed as well.
Re: Anti-freeze turned brown [Re: moparjim79] #2854573
12/02/20 09:48 PM
12/02/20 09:48 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Static (Cranking) and Dynamic (running). I'm doubting if either would show that small of a leak or a leak down test for that matter. I'm not trying to start a peeing contest just not understanding how any of the above would find that small of a leak.
I believe having the coolant analyzed would likely be the best approach or a chemical check for combustion gas in the system with the engine running :beer
