Page 7 of 8 1 2 3 4 5 6 7 8
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: stevet340] #28530
08/06/11 11:23 PM
08/06/11 11:23 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
" Tell this to Indy as they rake in the $$$$. "
W-5 heads are hard core race heads, Indy heads are for street monkeys...
just my
Puhleeze. Check out a set of 245RP's. lol
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hot 340] #28531
08/07/11 10:13 AM
08/07/11 10:13 AM
western PA
stevet340 Offline
stevet340  Offline
western PA
I have checked out the indy heads, I do every year at the nats, thats the only place I have ever seen a set, at their display tent. I would like to know how many sets they really have sold??? I go to quite a few different tracks and have never seen or heard of anyone in this part of the country ever running a set, I'm sure there are guys out there that do, and I would love to see them on a car, let alone a hard running car, but like my first post, it is hard for most guys justify the added expense of rockers, intake, machine work, etc, etc, etc, to go have fun at their local track. Even the highly touted edelbrock heads take special machine work and porting to make them run half decent. Special intake rockers, pushrod tubes, oiling mods, etc, etc, etc...
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: stevet340] #28532
08/07/11 10:34 AM
08/07/11 10:34 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Are you saying the W5s dont???
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: stevet340] #28533
08/07/11 10:38 AM
08/07/11 10:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Wow.....no one told me about the special rockers, pushrod tubes or oiling mods needed for my Edelbrocks. Mine have standard la rockers, no pushrod tubes or oiling mods, they are ported. Then again mine is not a real race car because I drive it on the street too. It does run 6.57 in the 1/8 though on pump 93 at 3260#.
What small block do you have?
BTW W5 use offset intake rockers.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: stevet340] #28534
08/07/11 11:10 AM
08/07/11 11:10 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Jim Blackmore
The car has a 360ci stroked to 408ci with INDY 360-2 heads,flow 326cfm @.700 int.,238cfm @.750exh.(265cfm with flow pipe).solid roller with gross lifts int.727,exh.697,dur.@.050 int.271.83, exh 291.59. 13:5.1 comp..904 flite with brake,stock 2.45 first ratio, and 6200 conv.dana-60 4.88 gears,33x14x15 slicks,car weighs 2680 with driver,ladder susp. leave on a 4200 chip,shift [Email]1st@7000[/Email] 2nd 7500, crosses @8000.SV-1 110mm Pro- systems carb.N.A.
Jim.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: stevet340] #28535
08/07/11 02:23 PM
08/07/11 02:23 PM
Guitar Jones Offline
When I first got my W5's there wasn't anyone around here running them either. In fact I've only ever seen 3 other cars with them in the southeast. Granted I don't get around a lot but still just the lack of known usage doesn't mean anything. Let's face it there just aren't a lot of people drag racing a SBM anywhere when you compare it to a SBC, BBC , SBF, or even a BBM.
I love my W5's and wouldn't mind having another set but there are other options and if I build another engine it will be a 48* block anyway so there are other options.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: W5DART66] #28536
08/07/11 06:39 PM
08/07/11 06:39 PM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
We have been working with Edelbrock for quite a while on a new small block Chrysler "Victor" head. We should have a prototype at our shop this week to get some preliminary flow numbers etc... You can expect some type of announcement (maybe even the actual release of the head) from Edelbrock around the P.R.I. show this December. From what we can tell this head is going to support well over 700HP. You guys are right about needing a head like this. We can't wait to get our hands on it!
Kevin @ Hughes Engines, inc.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hughes] #28537
08/07/11 07:23 PM
08/07/11 07:23 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Well that is exciting news! I emailed edelbrock about doing a victor head about 3 years ago. The response wasn't too exciting at that time, but the door sure wasn't shut on it. I think at that time they were still busy with a couple other heads they were releasing, one being the victor 440.
So, is this head going to use some sort of W2 valvetrain? Or will it be unique like the 440 victor was?
Thanks for sharing!
-Kenny
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hughes] #28538
08/07/11 10:12 PM
08/07/11 10:12 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
IF their actually goimg to do this but I won't be holding my breath.
The way the economy is headed I THINK you will see a HUGE downgrade.
Beside IMO the INDY 360 series is already up to the task. Matt
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: MattW] #28539
08/07/11 11:00 PM
08/07/11 11:00 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Kinda what I was thinking. Do we really need another straight valve 300~340 cfm head?
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hot 340] #28540
08/07/11 11:17 PM
08/07/11 11:17 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Short answer.........NO.
A serious straight head is needed......like a modern W8.
It's a joke that the 420 manifolds are being made because the readily available chevy heads need em'.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hot 340] #28541
08/07/11 11:31 PM
08/07/11 11:31 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
YES competition in the market place is a winner for everyone why would someone want only 1 choice when they can have more.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: dusturbd340W5] #28542
08/08/11 12:02 AM
08/08/11 12:02 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I wouldn't be putting myself into debt to produce them, I really doubt I would re-coup my money over 5 years. An updated W8 might be a different story.
Alan Jones
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: LA360] #28543
08/08/11 12:47 AM
08/08/11 12:47 AM
SoCal
Brian Hafliger Offline
SoCal
If they did what I hope they did, edelbrock should "potentially" have as good of a head as Indy at a lower cost. This is WHY we need more cylinder heads...indy's heads are ridiculously priced for what you get. They won't make any power unless they've been ported.
CFM is a POOR way to rate a cylinder head alone.
Brian Hafliger
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Brian Hafliger] #28544
08/08/11 01:11 PM
08/08/11 01:11 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
great news! and considering the indy part,indy sure needs some competition from what i have read on here they dont deserve most customers(not knocking on there dealers wich are doing a great job)
the more good heads there is out there for a reasonable cost the more people will run hot smallblocks wich may bring the price down eventualy on blocks. it could create a chainreaction in a very positive direction. hope im right on this
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Brian Hafliger] #28545
08/08/11 02:20 PM
08/08/11 02:20 PM
Alberta Canada
Alberta Canada
I agree with ya 100%!! I would assume it is a similar design to the Indy and W5 stuff, since this has been brought up in a W5 thread. Hopefully it is a raised port head that you can get a decent size port and CSA into!
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: jim sciortino] #28546
08/08/11 06:36 PM
08/08/11 06:36 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I guess it all depends on what you want to do. If you want to sell heads or buy a set of Indy~ish heads, then yes, the Victors will help the market in that reguard. But performance wise its beating a dead horse. I would love to see a updated 8 as mentioned, or a spayed valve head that didnt involve those funky dry sump short deck r5's with all the adapters or oddball cams. An SB2 head to slam on a wet sump tall 48 would be the shnizzle and a new open door. I know its only a dream.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hot 340] #28547
08/09/11 09:28 AM
08/09/11 09:28 AM
Trumbull,CT.
Trumbull,CT.
But a very nice dream.
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: Hughes] #28548
08/09/11 11:41 AM
08/09/11 11:41 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
This is great news. I look forward to their release of a new head and will be watching this closely. Their ability to produce leak free castings and the way they treat their customers is known world wide. If a person can take their old head from 240 cfm out of the box to 300+ it will be interesting to see where the new head stacks up.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone Interested In W5 Mopar Heads Please Read [Re: pittsburghracer] #28549
08/11/11 12:32 AM
08/11/11 12:32 AM
Toronto
mshred Offline
mshred  Offline
Toronto
This is great news! It may not be as exotic as a W8 redesign, but really the small block mopar crowd should not be complaining! Its another cylinder head choice (after all the brand x-er's have tons to choose from, why can't we?)
Can't wait to hear more as the time comes closer...Brian, im just wondering, is this the head you said a while back would be coming out eventually? or is that another dealio?
