? for Alasakan T/A (Barry) #2852738
11/28/20 10:01 PM
11/28/20 10:01 PM
Middle TN.
4x4 Roundup Offline OP
Middle TN.
Have a Nov. '69 casting date 340 with 0R258007 stamping on pan rail. Can you tell me what it came out of? Must be a Cuda or Challenger since it appears to have been used without the oil filter right angle adapter used on A-bodies. Thanks shruggy
WANTED-- DEAD or ALIVE:
'70 Duster--- VS29H0B274908-----UPDATE---ENGINE BLOCK FOUND---Still looking for the B-5 car.
'79 Power Wagon W14JE9S137761 or 763
Re: ? for Alasakan T/A (Barry) [Re: 4x4 Roundup] #2852745
11/28/20 10:10 PM
11/28/20 10:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
0R, so from a 1970 model from the Windsor, Ontario plant.
No E bodies from there.
They did make more Darts than Dusters though from what I have seen so far.
Re: ? for Alasakan T/A (Barry) [Re: Alaskan_TA] #2852749
11/28/20 10:20 PM
11/28/20 10:20 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I thought ALL 340 engines were cast and built in Windsor no matter what body they were going into?!? shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: ? for Alasakan T/A (Barry) [Re: 4x4 Roundup] #2852751
11/28/20 10:23 PM
11/28/20 10:23 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
it would've been a Swinger, 340 Swinger
the complete VIN would've been LM23H0R258007
Re: ? for Alasakan T/A (Barry) [Re: Rhinodart] #2852753
11/28/20 10:24 PM
11/28/20 10:24 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The partial VINs were stamped after the engines were built, just before they went into a car at the various car assembly plants.
Re: ? for Alasakan T/A (Barry) [Re: Alaskan_TA] #2852770
11/28/20 11:22 PM
11/28/20 11:22 PM
Middle TN.
Middle TN.
Thanks up up So I have a Dart engine that was used later in something that did not require the right angle oil filter base or after the engine was pulled the adaptor was misplaced and the regular base put on the engine just for the sake of having an oil filter base on it.
I kinda like that 007 ending vin scope
Re: ? for Alasakan T/A (Barry) [Re: 4x4 Roundup] #2852811
11/29/20 07:12 AM
11/29/20 07:12 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
somebody tried to swap it into an Aston Martin.
Angry white pureblood male
