Re: Riddle me this?
[Re: 500ciDuster]
#2853011
11/29/20 05:29 PM
11/29/20 05:29 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You ain't seen nothin' until you work on a modern car...ten pounds of s**t in a five-pound bag.
Re: Riddle me this?
[Re: slantzilla]
#2853635
12/01/20 12:14 AM
12/01/20 12:14 AM
Posts: 9,124 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Wait until you have to put points in it. Yep. Easier to just remove the distributor sometimes.
Re: Riddle me this?
[Re: John_Kunkel]
#2853813
12/01/20 02:51 PM
12/01/20 02:51 PM
Posts: 15,894 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
You ain't seen nothin' until you work on a modern car...ten pounds of s**t in a five-pound bag. I don't even try unless it's the most simple of tasks, such as changing the oil and filter. A friend of mine has Titan, and was just explaining the day long process of changing out the starter, which includes removing intake.
Facts are stubborn things.
Re: Riddle me this?
[Re: 500ciDuster]
#2989412
11/26/21 07:57 PM
11/26/21 07:57 PM
Posts: 16,826 Between Houston & Galveston TX
SattyNoCar
I put a fuel pump on one of my cars today & had to remove the overflow tank, alternator and coil to even see it to change it. To quote Top Gear: " Still, could be worse..........."
John
Re: Riddle me this?
[Re: volaredon]
#2989415
11/26/21 08:01 PM
11/26/21 08:01 PM
Posts: 4,432 Michigan
MarkZ
Worthy
Worthy
I'd. Rather work on the /6 in my truck any day over the piece of shyt F150s that await me getting to work daily. The state of Illinois owns a gazillion F150s 2008 and up. It's give and take. Did a fuel pump in a Caliber that died right before I offloaded the car. Two bolts to remove the rear seat, a plastic cover and a couple of quick disconnect fuel lines. Job was done in under 15 minutes. Want to replace an alternator in the same car when the clutch (yes, it has a clutch) breaks? Better part of an afternoon with it having to come out through the bottom of the car that involved removing a ton of plastic shielding, the tire and A/C compressor.
