Dominator air bleeds #285244
04/11/09 10:19 PM
04/11/09 10:19 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
has anyone cleaned up the idle swapping idle air bleeds ? this is a 1050 . What are the stock sizes , and how much bigger is recommended ? Ive already played with the mix screws and throttle blades , but it still seems pretyy rich at idle.
i dont remember off hand the list # on my carb , i know its something like 8082-1 . 4 corner idle mix . 3.5 Power valve in front , none in rear.
Also does anyone have any for sale? Looks like Jegs wants $20 a pair if i read it right.
Re: Dominator air bleeds [Re: 493_DART] #285245
04/11/09 10:24 PM
04/11/09 10:24 PM
Dunedin, Fl
DRDart Offline
mopar addict
DRDart  Offline
mopar addict
Dunedin, Fl
I have you could also find a local rebuild that has blank air bleeds much cheaper & drill them small & work your way up.
[image]http://i682.photobucket.com/albums/vv183/DrDart500/DSC00307.jpg 1966 Charger 1970 Dart 16-1,solid roller,500 ci Tunnel Ram 8" Ati conv,BTE glide, Fab 9 rear strange center sect. Twin Rons terminators on Alky.
Re: Dominator air bleeds [Re: DRDart] #285246
04/11/09 10:26 PM
04/11/09 10:26 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
First take them all the way out and see if that helps clean it up...It might not be the idle circuit at all. The outer ones by there self is the ones to omit for now...
Re: Dominator air bleeds [Re: Bob_Coomer] #285247
04/12/09 03:28 AM
04/12/09 03:28 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
?? what do you mean? take them out? I think that would be way lean.
like i said--ive tuned this one as far as its going to go--- still a bit rich at idle--as in..."get outa the garage soon" too rich exhaust... but not WAY too overwhelming....;)
Ive leaned it as far as i can without it dying at idle--idle is around 1000 .
EDIT---- ok, will try without the bleed jets.
Re: Dominator air bleeds [Re: 493_DART] #285248
04/12/09 07:09 AM
04/12/09 07:09 AM
use some carb cleaner withthe long tube nozzle first and make sure all the passages are clean.
you can also try increasing your idle bleed size .007-.010" that's plenty to see if it helps, and it normally does. there are other mods that canbe done also, but that's the easiest and cheapest to start out with.
Re: Dominator air bleeds #285249
04/12/09 07:19 AM
04/12/09 07:19 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
496. Ive been looking to get a bunch some myself.. the $20 is for a pack of 10....
my dominator came with Idle .045 / Mid .075 / Main .035
If there are some your looking at getting I can but the packs of ten and split the cost with you.. you only need 4 oarb..
Mopar Performance
Re: Dominator air bleeds [Re: moparniac] #285250
04/12/09 09:15 AM
04/12/09 09:15 AM
UK
602heavy Offline
602heavy  Offline
UK
Pretty unlikely you'll clean it up with an air bleed mod , especialy if it's the 3 circuit , lots have been covered on here regarding modifications to these carbs , had the same problem with the 8896 , changed out the metering block gasket for a 4150 & restricted the IFRs with some wire , it'll never clean up so long as yer running tight lobe seps & long duration cams , spits out raw fuel @ overlap , tis the nature of the beast.
Re: Dominator air bleeds [Re: 493_DART] #285251
04/12/09 11:04 AM
04/12/09 11:04 AM
Cab_Burge Online work
Cab_Burge  Online Work
? Whats the results? I have been able to clean up the idle mixture by using 1/4 to 1/2 turn out from bottom on all four idle mixtures screws and increasing )(.003 to .008)the idle bleed diameter also That was on 4150 DP carbs and soem 1050 Dominators, the Dominators list numbers circuits inside are differnt carbs from each other as already mentioned
Re: Dominator air bleeds [Re: 493_DART] #285252
04/12/09 11:10 AM
04/12/09 11:10 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
What is your ignition timing at idle? Needs to be around 18 to 20 degrees for a clean idle.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Dominator air bleeds [Re: Cab_Burge] #285253
04/12/09 11:11 AM
04/12/09 11:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Holley's website has a numerical listing with the air-bleed sizes per list number carb.
Bob
Re: Dominator air bleeds [Re: fbs63] #285254
04/12/09 12:06 PM
04/12/09 12:06 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
if throttle blades are not set properly, you will chase this problem forever. that would be the first thing i check
Re: Dominator air bleeds [Re: sixpackgut] #285255
04/12/09 04:44 PM
04/12/09 04:44 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
ive set the blades as low as they can , and also the mix screws. I think they are around 1.5 turns out. Anymore inward and the car dies.
I will fire it today hopefully and check the timing + remove the bleeds to see what happens.
Re: Dominator air bleeds [Re: 493_DART] #285256
04/12/09 05:27 PM
04/12/09 05:27 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Letting it idle like that some wont hurt it a bit, I didnt mean to toss them in the trash, this would just be away to pin point the problems. If this doesnt clean it up, your idle circuit isnt the problem.
You need to back the speed screws all the way out from touching, them give the front about 3/4-1 turn in after contact, give the rear a little more about 1 1/2 turns. Turn the idle mixture screws all the way in, and then back out 3/4 of a turn, fine tune from there.
Make sure the float level is correct, Dominators are pretty sensitive on floar adjustment. Set them low enough to were you have to bounce on the car to get fuel to run out while idling, then turn it in another 1/3 turn down. Again Fine tune from there..
If your timing isnt up to snuff at idle, no carb tuner in the world can make it idle clean....
Big cam.....get about 20 deg intial, other wise pointless to tune any more
Re: Dominator air bleeds [Re: Bob_Coomer] #285257
04/12/09 10:24 PM
04/12/09 10:24 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
YOu can try this little trick, take the air bleed completly out of the intermediate and high speed circuits. This should effectivly dissable them or at least desensitise them for idle tunning. If for some reason the throttle blades are open to far, it can be taking fuel from the intermediate circuit. If removing the air bleeds from those circuits makes it better, you may need to go up on the intermediate air bleeds.
Allan G
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Dominator air bleeds [Re: turbobitt] #285258
04/12/09 10:38 PM
04/12/09 10:38 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
too late to start the car tonight...
But, i cant find any info on my carb its NOT listed on Holleys site!
its a 80823 , 2 circuit idle . Im wanting to know the stock jet size / bleed sizes / pv sizes . Ive searched the web now for 30 minutes.
my int. bleeds are 37 and the idle bleeds are 71
Re: Dominator air bleeds [Re: 493_DART] #285259
04/12/09 10:47 PM
04/12/09 10:47 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Im no carb expert but arent those numbers backwards...
Mopar Performance
Re: Dominator air bleeds [Re: moparniac] #285260
04/12/09 11:21 PM
04/12/09 11:21 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i dont know------like i said , i cant find any info on sizes
can anyone tell me what size bleeds need to be where ?
Re: Dominator air bleeds [Re: 493_DART] #285261
04/13/09 12:17 AM
04/13/09 12:17 AM
Call the Holley tech line, I couldn't find any bleed size information on Holley tech library either If you talk to them suggets adding that information onto the tech site library
Re: Dominator air bleeds [Re: Cab_Burge] #285262
04/13/09 12:59 AM
04/13/09 12:59 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
i can tomorrow --or if someone could take a quick look at their 4500 .......
Re: Dominator air bleeds [Re: 493_DART] #285263
04/14/09 09:16 PM
04/14/09 09:16 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I fired it today . Initial is about 15-16 degrees , 35 total .
i pulled 2 bleeds out at a time , the idle didnt change. With 3 out , it would die.
In other words it will idle with either the rear 2 bleeds removed , or the front 2 . Dont know if that tells ya anything...
I do have an advance kit coming for the dist. Its a MP .
