426 Hemi with A/C #2852328
11/27/20 08:55 PM
11/27/20 08:55 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
I know certain cars with 440 and certain hoods didnt have A/C. Like a 69 Coronet R/T with an air grabber didn't have A/C. But my question , did they ever put A/C on a 426 Hemi ?? Don't know enough about hemi's and the brackets and accessories if they could or never did in cars. Thoughts?
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 426 Hemi with A/C [Re: hulmule] #2852333
11/27/20 09:06 PM
11/27/20 09:06 PM
Kirkland, Washington
Pacnorthcuda Offline
No 426 Hemi AC cars.
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852336
11/27/20 09:11 PM
11/27/20 09:11 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
So my next question, not knowing bracketing . Could you put an A/C unit on 426 and look somewhat stock ?
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 426 Hemi with A/C [Re: hulmule] #2852341
11/27/20 09:20 PM
11/27/20 09:20 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I put Air on a 1970 Cuda with hemi. Its one of the smaller sanden style compressors . But to be honest I dont remember if it was Vintage Air or Antique auto air
I'll ck with the cars owner and see if he can send me some pictures of it
Re: 426 Hemi with A/C [Re: gtx6970] #2852351
11/27/20 09:34 PM
11/27/20 09:34 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Cool thanks !!
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 426 Hemi with A/C [Re: hulmule] #2852356
11/27/20 09:40 PM
11/27/20 09:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
If you can fab your own brackets you mount the compressor low on the passenger side, under the alternator. You'd have to run an electric fuel pump but you could stick with the OEM air filters and keep a stock-ish appearance under the hood. twocents
Re: 426 Hemi with A/C [Re: hulmule] #2852357
11/27/20 09:40 PM
11/27/20 09:40 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I've done a couple. Both Cudas with a shaker hood.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852371
11/27/20 09:56 PM
11/27/20 09:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....hmmmmm.... factory install and a V2 no less...
Re: 426 Hemi with A/C [Re: DAYCLONA] #2852389
11/27/20 10:53 PM
11/27/20 10:53 PM
Not a Mopar in the spirit of this thread, but rather a very cool oddball vehicle.
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852391
11/27/20 11:01 PM
11/27/20 11:01 PM
moparmarks Offline
moparmarks  Offline
So what car is that?
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 426 Hemi with A/C [Re: moparmarks] #2852392
11/27/20 11:02 PM
11/27/20 11:02 PM
Monteverdi. I think you can count the production numbers on one hand.
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852399
11/27/20 11:35 PM
11/27/20 11:35 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
This Hemi Dart has A/C, on the left of the picture where the alternator usually is...
JB Rhinehart, Realist
A-Body's RULE!
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852631
11/28/20 04:36 PM
11/28/20 04:36 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Mopar powered from the Monteverdi factory, point was to show a V2 compressor can be mounted atop a 426 DQ and function with stock Mopar components.....
I also have a pic of a 70 Challenger T/A w 340/6 and T/A factory hood and T/A 6 pack air cleaner with a V2 mounted up top in the stock location using factory style bracket, granted it was owner made, but with enough thought and preservation anything can be made to happen
Mike
Re: 426 Hemi with A/C [Re: hulmule] #2852757
11/28/20 10:36 PM
11/28/20 10:36 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Check with Andy F (AR Engineering). Not sure he makes it, but worth a shot.
Re: 426 Hemi with A/C [Re: Pacnorthcuda] #2852764
11/28/20 10:59 PM
11/28/20 10:59 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree
I saw a 1968 Charger that the owner had installed a 426 Street Hemi motor in and he had installed a stock Mopar V twin air conditioning compressor on it up high on the passenger side like Mopar installed them on the 440 motor back in the mid 1970s before the first gas crisis.
I think he worked in the Dodge Dealership In San Bernardino, CA as a mechanic so he may have had access to some Mopar parts you and I couldn't get back then to do that install with confused He said the air worked really good, it does get above 100 F frequently in the summer down there.
I've never seen or heard of any other stock Street Hemi productions cars having air conditioning stock from the factories. shruggy
Re: 426 Hemi with A/C [Re: hulmule] #2852810
11/29/20 07:09 AM
11/29/20 07:09 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Originally Posted by hulmule
I know certain cars with 440 and certain hoods didn't have A/C. Like a 69 Coronet R/T with an air grabber didn't have A/C. But my question , did they ever put A/C on a 426 Hemi ?? Don't know enough about hemi's and the brackets and accessories if they could or never did in cars. Thoughts?
Chrysler did indeed install six paks with ac on a few e bodies. See attached - they did not perform the ac in an e-body 6 pak exercise just for grins. I am sure they did the same with hemis based on research and interviews from people involved in the Chrysler car building & engineering culture of the times. Interviews & Research with real people. whistling
In some one's collection is a red 1970 Challenger JS27V0B with factory ac that came out of the Brian Thomas Collection. Factory Exec car on the tag and H51, misprint according to all the experts....can't be done... The air breather notch for the compressor had rolled edges as it was cut with a die not a cutting tool. Brian Thomas was arrested for securities/stock fraud and the cars auctioned by the fed. Got time on your hands? - go look for the auction/crime info from the mid late 80's and you may find the story. Rochester NY newspaper would be a good place to start looking. work
Further research indicates over the last 40 yrs that there was an E body hemi or 2 built in late 1970 model yr with factory AC & H51 on the tag.
Try JH23R0B not JS27R0B. Not a miss-print. One of hemi owners who is well known in the blue oval world of never say never built fords has readily offered to provide an affidavit regarding the ac in the hemi Challenger. Argue with him.
A couple of those cars may actually exist but i am not allowed to divulge any further info, just like Ryan and his auto archaeology finds where he protect the locations/owners of the cars he finds.
There may even be a broadcast sheets for these unicorns but the masses will never get to see them due to the owners wishes.
There is a 1971 Challenger JS23V1B Factory exec car with H51 on the tag and ac in the car...documentation exists
I don't give a crap if you think this is an old wives tale. Be happy I shared my years of controversial research chasing the unicorns & remember I am just the messenger who knows better. I will not be returning to argue - have ???? Try a PM
catfight
drive
Re: 426 Hemi with A/C [Re: ThermoQuad] #2852817
11/29/20 08:58 AM
11/29/20 08:58 AM
moparmarks Offline
moparmarks  Offline
All though not a Hemi I put a shaker hood on a 71 Challenger 340 with factory A/C.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 426 Hemi with A/C [Re: moparmarks] #2852843
11/29/20 11:31 AM
11/29/20 11:31 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
our serpentine belt kits make it really easy to put ac on a hemi engine.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 426 Hemi with A/C [Re: moparmarks] #2852849
11/29/20 11:45 AM
11/29/20 11:45 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Re: 426 Hemi with A/C [Re: ThermoQuad] #2853071
11/29/20 07:28 PM
11/29/20 07:28 PM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
catfight
drive
...coded for the extremely rare air cleaner delete option.
