426 Hemi Chrome Valve Covers #2850330
11/23/20 10:48 AM
11/23/20 10:48 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Who sells the best stamped chrome valve cover for the 426 Hemi? All I hear is the Chinese junk floating around is thin garbage that everyone hates. There must be some good ones sold somewhere. May consider some chrome or polished finned cast model. Want the old school look in a valve cover. Someone got something laying around. Talked to a chrome plating company a few years ago and they want $400 to re-plate an original set. Thanks
Re: 426 Hemi Chrome Valve Covers [Re: maximus] #2850544
11/23/20 03:15 PM
11/23/20 03:15 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
RBRE sells a set that will clear most aftermarket springs. OEM ones will not.
Re: 426 Hemi Chrome Valve Covers [Re: Dragula] #2850805
11/24/20 01:30 AM
11/24/20 01:30 AM
Walla Walla, WA
Hemi_Jack Offline
Hemi_Jack  Offline
Walla Walla, WA
These things are expensive! Stage V are the good ones.
http://www.goodvibesracing.com/valve_covers.htm#426%20covers
Re: 426 Hemi Chrome Valve Covers [Re: Hemi_Jack] #2850866
11/24/20 10:25 AM
11/24/20 10:25 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Arruzza used to sell some that work. I heard he's back. The last set I got off ebay from that guy in New York didn't fit at all and he won't exchange them or return my messages. So that money is gone.
2011 Drag Pak Challenger
Re: 426 Hemi Chrome Valve Covers [Re: rickseeman] #2850881
11/24/20 11:30 AM
11/24/20 11:30 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
What diameter springs are you guys having issues with? Mine came with chrome covers and 1.55 diameter springs with no clearance issues. (I'm running 1.4 now)
Re: 426 Hemi Chrome Valve Covers [Re: INTMD8] #2850917
11/24/20 02:14 PM
11/24/20 02:14 PM
Dragula Offline
Dragula  Offline
Whatever the standard is....I don't know, but the last set of OEM covers we had wore out right where the springs rubbed thru. And my bad, RBRE does not seem to list the stamped chrome ones anymore....
Re: 426 Hemi Chrome Valve Covers [Re: Dragula] #2851642
11/26/20 12:11 AM
11/26/20 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have a pair on the wall in chrome and all the heated & beated outward dents to clear. The chrome will crack some with this clearancing method.I used JB weld on the inside of the covers ti fill the cracks. Use ALOT of heat!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 426 Hemi Chrome Valve Covers [Re: hemi-itis] #2851663
11/26/20 04:40 AM
11/26/20 04:40 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I'm still curious what diameter spring you guys are using that has this problem.
I thought 1.55 was big, is there something actually bigger than this? Or, is it a clearance problem because of longer valves or rocker arms?
Re: 426 Hemi Chrome Valve Covers [Re: INTMD8] #2851781
11/26/20 12:21 PM
11/26/20 12:21 PM
hemi-itis Offline
hemi-itis  Offline
The rockers are meaty and the additional lift makes the rocker hit the cover.
Re: 426 Hemi Chrome Valve Covers [Re: hemi-itis] #2851813
11/26/20 01:31 PM
11/26/20 01:31 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
So the rocker adjuster is what's hitting? The valve side should gain clearance with more lift, no?
I bought shorter adjusters for mine so only one thread or so above the lock nut.
Re: 426 Hemi Chrome Valve Covers [Re: INTMD8] #2851837
11/26/20 02:19 PM
11/26/20 02:19 PM
hemi-itis Offline
hemi-itis  Offline
I installed the covers,spun the hemi over then removed the covers to see the witness marks. Heat and a ballpeen hammer!
Re: 426 Hemi Chrome Valve Covers [Re: hemi-itis] #2851883
11/26/20 03:25 PM
11/26/20 03:25 PM
How about double stacking the thick valve cover gaskets with the Milidon spark plug tube seals work scope twocents
Re: 426 Hemi Chrome Valve Covers [Re: Cab_Burge] #2851974
11/26/20 08:03 PM
11/26/20 08:03 PM
Stuttgart, Arkansas
Stuttgart, Arkansas
The plug tubes aren't really long enough for that. Just need to buy a set from Arruzza that work.
Re: 426 Hemi Chrome Valve Covers [Re: rickseeman] #2852071
11/27/20 08:03 AM
11/27/20 08:03 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Mancini Racing sells valve covers spacers that are .188 thick for anybody that needs them.
Re: 426 Hemi Chrome Valve Covers [Re: maximus] #2852076
11/27/20 08:28 AM
11/27/20 08:28 AM
N.Y.
sixpacksteve Offline
N.Y.
i double stacked mine, got longer tubes from tim @FHO.
so far so good.
Hell Hath No Fury Like Mine
Re: 426 Hemi Chrome Valve Covers [Re: sixpacksteve] #2853078
11/29/20 07:45 PM
11/29/20 07:45 PM
California
mickm Offline
mickm  Offline
California
so far so good.
Same here...
