Re: Challenger 1970 tail light lens and chrom bezels from B E &A
[Re: fury4speed]
#2851432
11/25/20 03:37 PM
11/25/20 03:37 PM
Posts: 7,371 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
these had the Chrysler markings on them and there out at the moment BE&A was in partnership with PG Classics. BE&A's parts were run first, then the part numbers were removed from the molds. Then PG's parts were run. Once BE&A is out of a part that has the correct #s on it, they have no way to get more. The numbers have already been removed from the tooling that makes the parts. At least this is how it was explained to me years ago. I hope you find what you're looking for. You should start a want ad in the "Parts Wanted" section.
[Re: fury4speed]
#2851447
11/25/20 04:13 PM
11/25/20 04:13 PM
Posts: 21,453 It's a dry heat
gtx6970
It's a dry heat
Once the bezels are on the car....#s cant be seen
EDIT, Although Im not sure if the current PG lenses have the numbers on them or not
[Re: gtx6970]
#2851490
11/25/20 05:52 PM
11/25/20 05:52 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Once the bezels are on the car....#s cant be seen Bill, some guys sleep better at night knowing the numbers are there, even if it's repro parts...lol! Mike
