Re: 426 Hemi Chrome Valve Covers
[Re: Hemi_Jack]
#2850866
11/24/20 10:25 AM
11/24/20 10:25 AM
Posts: 2,654 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Arruzza used to sell some that work. I heard he's back. The last set I got off ebay from that guy in New York didn't fit at all and he won't exchange them or return my messages. So that money is gone.
2011 Drag Pak Challenger
[Re: rickseeman]
#2850881
11/24/20 11:30 AM
11/24/20 11:30 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
What diameter springs are you guys having issues with? Mine came with chrome covers and 1.55 diameter springs with no clearance issues. (I'm running 1.4 now)
[Re: INTMD8]
#2850917
11/24/20 02:14 PM
11/24/20 02:14 PM
Posts: 12,397 Taxes & Virus's R-US, NY
Dragula
Whatever the standard is....I don't know, but the last set of OEM covers we had wore out right where the springs rubbed thru. And my bad, RBRE does not seem to list the stamped chrome ones anymore....
[Re: Dragula]
#2851642
11/26/20 12:11 AM
11/26/20 12:11 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I have a pair on the wall in chrome and all the heated & beated outward dents to clear. The chrome will crack some with this clearancing method.I used JB weld on the inside of the covers ti fill the cracks. Use ALOT of heat!!
[Re: hemi-itis]
#2851663
11/26/20 04:40 AM
11/26/20 04:40 AM
INTMD8
Lake Villa Il
I'm still curious what diameter spring you guys are using that has this problem.
I thought 1.55 was big, is there something actually bigger than this? Or, is it a clearance problem because of longer valves or rocker arms?
[Re: INTMD8]
#2851781
11/26/20 12:21 PM
11/26/20 12:21 PM
hemi-itis
The rockers are meaty and the additional lift makes the rocker hit the cover.
[Re: hemi-itis]
#2851813
11/26/20 01:31 PM
11/26/20 01:31 PM
INTMD8
Lake Villa Il
So the rocker adjuster is what's hitting? The valve side should gain clearance with more lift, no?
I bought shorter adjusters for mine so only one thread or so above the lock nut.
[Re: INTMD8]
#2851837
11/26/20 02:19 PM
11/26/20 02:19 PM
hemi-itis
I installed the covers,spun the hemi over then removed the covers to see the witness marks. Heat and a ballpeen hammer!
[Re: maximus]
#2852076
11/27/20 08:28 AM
11/27/20 08:28 AM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
i double stacked mine, got longer tubes from tim @FHO. so far so good.
Hell Hath No Fury Like Mine
[Re: sixpacksteve]
#2853078
11/29/20 07:45 PM
11/29/20 07:45 PM
Posts: 4,179 California
mickm
California
i double stacked mine, got longer tubes from tim @FHO. so far so good. Same here...
