Page 5 of 6 1 2 3 4 5 6
Re: Water Wetter opinions ????? [Re: DaveRS23] #2849691
11/21/20 07:17 PM
11/21/20 07:17 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Originally Posted by DaveRS23
I'll throw this in here; When I built my first stroker, it would heat up around town, did good on the road, but got warm at slow speeds and them would boil over from heat soak when I parked it. Annoying and embarrassing. After a lot of experimenting, I pulled a fan from (I think) an 80s Dodge pick-up. It is huge. The blades are big and have a lot of pitch to them. The problem was, of course, that it wouldn't fit in the Cuda's shroud. It would fit the clutch just fine, but was too big to go into the shroud.
Fortunately, the blades are aluminum. I just marked them, cut them down to size and installed it. That did it. It moves an enormous amount of air. I had it on that engine for several years and have now had it on this Hemi for 4 or 5 years. But it will wear out a clutch every few years, depending on the amount of driving time it gets.
The fan may not be perfectly round or in balance. But it has not given me any problems and I spin the Hemi to 7,000.
Just one experience.
Thanks for the note.
Thats the way Im headed I think. Move more air . Although I would prefer a direct drive non clutch fan
Re: Water Wetter opinions ????? [Re: gtx6970] #2850067
11/22/20 06:21 PM
11/22/20 06:21 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Just to confirm , changing to a smaller diam upper pulley with no change to the lower speeds the fan up correct ?
Re: Water Wetter opinions ????? [Re: gtx6970] #2850087
11/22/20 06:44 PM
11/22/20 06:44 PM
Kirkland, Washington
Pacnorthcuda Offline
Correct. And speeds up the water pump too of course.
Re: Water Wetter opinions ????? [Re: Pacnorthcuda] #2850124
11/22/20 08:14 PM
11/22/20 08:14 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ok,
I had nothing to loose so I wanted to try something .
So,,,, I put it back together with what I have. I gutted the original 160 thermostat. so now its nothing but a restrictor plate. I also bumped timing back up to 19 degrees base. Refilled it straight distilled water , added maybe a cup more of the cooling system additive. As the bottle says treats up to 12 quarts. this one was closer to 15 qts. Took it for a 25 mile test drive. So far so good. Its stayed well below half way on the gauge. Which by my earlier test , halfway is right at 190
Ambient temps during said ride were low 80s temps
Im going to drive it several times in a couple different environments before doing anything else to it
And as soon as I find a place its hidden , I will be adding a aftermkt gauge just for good measure before going any deeper.
Re: Water Wetter opinions ????? [Re: gtx6970] #2850125
11/22/20 08:15 PM
11/22/20 08:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Do you have a spring in the lower radiator hose?
Re: Water Wetter opinions ????? [Re: Neil] #2850129
11/22/20 08:27 PM
11/22/20 08:27 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
yes, added one while I had it apart the other day . Before I did this last test
Re: Water Wetter opinions ????? [Re: gtx6970] #2850135
11/22/20 08:36 PM
11/22/20 08:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Ok, I figured you'd know to do that, but since you bought the car maybe the previous owner did not.
My dad owns a chevy nova and his radiator temps were sky high on hot summer days according to the temp gauge, and it turned out to be a defective sending unit and nothing more.
Re: Water Wetter opinions ????? [Re: Neil] #2851558
11/25/20 08:14 PM
11/25/20 08:14 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
UPDATE,
worked on it today
I bought and Installed a mechanical gauge today. So far , so good.
I also put an overflow bottle on it so it doesnt mark its spot anymore As the rad cap is a newer model designed for a return system .
Got it all warmed up sitting at high idle ,,,,, and the stock dash gauge needle pointing straight up the mech gauge is showing right at 170ish . Im gonna run it a while and see where it operates regularly . Im really starting to think im chasing a bad gauge or sending unit.
Re: Water Wetter opinions ????? [Re: gtx6970] #2851677
11/26/20 06:51 AM
11/26/20 06:51 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Good progress!
Now on to reducing pinging to where you do not need to use a special gasoline blend?
You still might want a higher flow fan.
Re: Water Wetter opinions ????? [Re: 360view] #2851685
11/26/20 07:46 AM
11/26/20 07:46 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Originally Posted by 360view
Good progress!
I am planning a different fan , maybe. I want to drive it a bit and make sure all is good. before doing anything else cooling system wise .
As far as reducing the race gas mix thing. THAT'S gonna require a complete tear down and new pistons. Thats a project for a day down the road a ways. Its not an everyday driver so $100 fuel tank fill ups dont really bother me to much .
Re: Water Wetter opinions ????? [Re: gtx6970] #2851689
11/26/20 08:09 AM
11/26/20 08:09 AM
USA
3
360view Offline
360view  Offline
3
USA
Re: Water Wetter opinions ????? [Re: gtx6970] #2854063
12/01/20 10:32 PM
12/01/20 10:32 PM
BlueRacer69 Offline
BlueRacer69  Offline
UPDATE,
worked on it today
Got any updates? popcorn
Re: Water Wetter opinions ????? [Re: BlueRacer69] #2854085
12/01/20 11:20 PM
12/01/20 11:20 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
UPDATE,
worked on it today
Ive had it out a couple times . So far the car runs SUPER cool. Like below 150 degrees to cold cool with the gutted thermostat . IMO to cold . Keeping in mind ambient temps have been a tad chily around here
I have a couple different temp range Stewart Components high flow thermostats coming and plan to replace both radiator hoses while its apart this time.
Re: Water Wetter opinions ????? [Re: gtx6970] #2854116
12/02/20 12:37 AM
12/02/20 12:37 AM
AndyF Offline
AndyF  Offline
If it runs cold without a thermostat then your cooling system should be fine. Sounds like your old thermostat wasn't working properly. I had the same issue with an issue. The thermostat checked out okay when tested in hot water on the stove, but it made the engine overheat. It was a new thermostat but it didn't work properly. The next new one solved the problem. Lots of junk for sale at the auto parts store these days.
Re: Water Wetter opinions ????? [Re: AndyF] #2854146
12/02/20 07:17 AM
12/02/20 07:17 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
My thoughts exactly
New Stat should be here today or tomorrow
Re: Water Wetter opinions ????? [Re: gtx6970] #2856754
12/07/20 07:48 PM
12/07/20 07:48 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
One step closer.
Stant superstat on the left.
Stewart industries high flow on the right.
It with new radiator hoses go on this week.
Time will tell soon enough if im on the right track
Re: Water Wetter opinions ????? [Re: gtx6970] #2856768
12/07/20 08:27 PM
12/07/20 08:27 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
just a word about water wetter. [which was the orig question] from what I remember , it was used to help prevent water from flashing into a vapor [ due to hot spots in the cyl head ] and I think it helped keep air/vapor pockets from forming on the back of combustion chambers. the term surface tension was what they used. it was very effective for that reason. it made that part of the cooling system work better which could lower temps some overall. the big gain as I understood it , was better control of combustion due to the elimination of hot spots. iirc, the gm vortec head with a closed combustion chamber had added front to rear coolant lines to the heads that were all about this same issue. they were so efficient that timing of 32* made best power. also, most racing sanctions don't allow any antifreeze, so this was helpful for lube and corrosion too ...
Re: Water Wetter opinions ????? [Re: ek3] #2856788
12/07/20 08:58 PM
12/07/20 08:58 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Thanks,
I used Rislone water treatment ( couldn't get Water wetter locally ) and So far so good.
with a gutted thermostat in it the car runs in the 130-140 range running down the road ,,,which is obviously to cold ( including expressway ) , It gets to maybe 160 ish range at extended idle
Im thinking I may pull and send the radiator out to Glen-ray next spring when the car hibernates for the hot summer . But will see where its running at that point in time
Re: Water Wetter opinions ????? [Re: gtx6970] #2857484
12/09/20 07:33 AM
12/09/20 07:33 AM
USA
3
360view Offline
360view  Offline
3
USA
Thanks,
while you have the gutted thermostat in and the weather is cool,
it might be a good time to do some experiments
on pinging versus coolant temperature.
Years ago (about 1999)
I decided to do an Oxalic Acid flush of the cooling system of the Magnum 5.9V8 in a 1995 Ram.
With distilled water, Prestone Oxalic Acid flush and no thermostat
I pretty quickly noticed that the light pinging on 85 AKI gasoline I usually had in the hot 95-99 North Carolina summer weather disappeared.
My coolant gauge and scanner readings showed 145 degrees coolant temperature.
I tested for pinging on a steep 4% grade hill by going to full throttle in 2nd gear.
My fuzzy memory is that a 10 degree coolant temperature change leads to 5 Octane number fuel requirement change.
Re: Water Wetter opinions ????? [Re: gtx6970] #2857493
12/09/20 08:17 AM
12/09/20 08:17 AM
SE Pa.
LimeliteAero Offline
SE Pa.
One step closer.
Bill do you mind relaying what degree thermostat you installed?
