Re: need help on smoking 440 [Re: RapidRobert] #284997
04/13/09 03:54 PM
04/13/09 03:54 PM
fresno
hyefatman Offline OP
fresno
what about damage to valve stems seals or guides -- that would cause the smoke- i just can not buy the fact that i haVE two problems-- a leaking intake and a push rod out of place-- some thing caused that push rod to fall out--
Re: need help on smoking 440 [Re: hyefatman] #284998
04/13/09 04:12 PM
04/13/09 04:12 PM
the harmonics & valve train bouncing caused the push rod to jump when you got on it. a loose guide or a bad seal could cause your symtoms but generally not as MUCH smoke as you are reporting plus the fact that this is a fresh eng & if the guide clearance was correct when the heads were done nothing could have messed them up(not that quick). 2 problems happening simultaneously will(& has) confuse a person like nothing else. I would just hate to see you pull the heads & intake & put it together & be thinking that the head was the problem when the heads were fine & changing(or resealing) the valley pan gasket along with it was what really fixed it. The intake is a MUCH more likely cause & much easier & cheaper to do.
Re: need help on smoking 440 [Re: RapidRobert] #284999
04/13/09 05:45 PM
04/13/09 05:45 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
Three things will cause a pushrod to come out of the rocker.
1. Is obvious, it wasn't properly in the rocker cup to begin with.
2. The rod gets bent, usually caused by either the lifter pumping up and staying there, or the associated valve sticking shut (or possibly even just a bad/weak pushrod). What valve springs did you use?
3. Some wear in the rocker cup that causes the rod to jump out. I have seen factory rockers so worn that the pushrod comes up through them!
I have also seen replacement valve seals that simply didn't seal well, but I too would suggest that you check out the intake gasket first!
Re: need help on smoking 440 [Re: polkat] #285000
04/13/09 06:03 PM
04/13/09 06:03 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I suggest taking it fro a short drive first if it isn't still missing and give the engine a chance to clean out. Sitting idling just don't cut it.
Re: need help on smoking 440 [Re: MoparforLife] #285001
04/13/09 08:20 PM
04/13/09 08:20 PM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
I had a 72 440 once that the guy said had developed a miss, so I got it cheap. You could see the heads had been hot tanked and he said it ran fine and then started missing so he parked the car and it rotted down into the ground.
SO I got the engine home, pulled the valve cover and found one pushrod laying. One end of it had sharpened to a point.
I noticed it had new, thick composite Fel Pro style head gaskets. So I ordered a new set of pushrods and new steel shim factory type gaskets.
Installed all that stuff and a set of good stock rockers and was good for over 10K miles and still good when I sold that car it was in.
I think that block/head combo had a bad tolerance stack, and the double what stock thickness gaskets made that pushrod on the end cylinder not have enough preload so it moved around and failed.
Now is that like your problem? Who knows...
Re: need help on smoking 440 [Re: SomeCarGuy] #285002
04/14/09 12:55 AM
04/14/09 12:55 AM
fresno
fresno
i went ahead and tighten down the intake bolts- its hard to drive the car because of little bugs i need to work out of it ... but i took it for a drive around the block and stepped on it-- the good news is NO SMOKE-- not to say it will not show up latter but as of 2day NO SMOKE-- need to work on the front end- adj timing and carb and start making this charger road worthy..
Re: need help on smoking 440 [Re: hyefatman] #285003
04/14/09 02:53 AM
04/14/09 02:53 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
What kind of rocker arms are you using? You have not said. Factory setup or adjustable?
Hydraulic cam and lifters?
More info please
Re: need help on smoking 440 [Re: pacifica] #285004
04/14/09 06:49 AM
04/14/09 06:49 AM
Upper Midwest
Upper Midwest
Good to here. I have seen many times that it seems to take for ever to clean out at idle but a short loaded drive and complete warm up is a lot more effective. Hope it stays clean for you.
Re: need help on smoking 440 [Re: pacifica] #285005
04/14/09 10:11 AM
04/14/09 10:11 AM
fresno
fresno
this is a stock 440 hp rebuild ...What kind of Factory setup with Hydraulic cam and lifters..
... i am going to remove the valve cover again and check the push rod and rocker arms to make sure it still looks good- this motor is fast- even with the problem- i have a lot of 383 which i love but have not driven this car since high school (1982) it seems to move- i am still concerned about oil pressure drop down to 20 after warm up but jumps up to 40-45 when driving
--when oil is cold prussure is at 55-60--also i
need to check my water temp its going to 220 may need to check Thermostat to see if is opening or get a lower temp one-
Re: need help on smoking 440 [Re: hyefatman] #285006
04/14/09 12:02 PM
04/14/09 12:02 PM
A next heavier wt of oil would up your psi a bit & when you take the stat out to check it take it out for a drive w no stat for a day which will tell you if the stat itself was restricting the flow or if the prob is elsewhere. It'll take longer to warm up but that wont hurt you for just (1) day.
