COPE'S TRANSMISSIONS #2849654
11/21/20 05:59 PM
11/21/20 05:59 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
Is he or it still in business? I had thought I saw it in the banners, but can't get it to come up.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: COPE'S TRANSMISSIONS [Re: Magnumguy] #2849656
11/21/20 06:06 PM
11/21/20 06:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
He is still in Business
Re: COPE'S TRANSMISSIONS [Re: Magnumguy] #2849657
11/21/20 06:07 PM
11/21/20 06:07 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
https://www.coperacingtrans.com/
Re: COPE'S TRANSMISSIONS [Re: PolyDart] #2849855
11/22/20 09:47 AM
11/22/20 09:47 AM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Just got my transmission back from him on friday, from being freshened up. Was in car for 711 passes, 5 years.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: COPE'S TRANSMISSIONS [Re: Dartsport540] #2849859
11/22/20 10:31 AM
11/22/20 10:31 AM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I have one of his transmissions, Best darn transmission I have ever had..
6.50 @105.26
Re: COPE'S TRANSMISSIONS [Re: Kindafast] #2850987
11/24/20 04:39 PM
11/24/20 04:39 PM
montana
BANDIT Offline
BANDIT  Offline
montana
The one he built for my 64 Coronet back in Early 2000's was great, havent run it since he freshened it up. As some of you know, he didnt do such a bang up job on the 48RE in my tow truck. What should have been a simple $2000.00 rebuild, cost me $3500.00 and a lot of aggravation, because of sloppy workmanship and 2 incorrectly specified converters. I'm sure you can find the story in archives, pictures, too. Jim.
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: COPE'S TRANSMISSIONS [Re: BANDIT] #2851080
11/24/20 08:24 PM
11/24/20 08:24 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
One of the members here recently bought a new 904 from him. Had incorrect part in it. He had to hire someone to fix it so he didn't have to pull it out again.
Re: COPE'S TRANSMISSIONS [Re: markz528] #2851256
11/25/20 08:39 AM
11/25/20 08:39 AM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I stopped using him as he turned out to be an a$$h0le when dealing with him. Very courteous though when he is taking your CC number.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: COPE'S TRANSMISSIONS [Re: ChrgrCuda] #2851266
11/25/20 09:00 AM
11/25/20 09:00 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I was looking to buy a valve body a few years ago and I prefer the standard pattern. He told me I needed to man up and get a real man's reverse valve body so I placed my order elsewhere for a STANDARD pattern one.
Re: COPE'S TRANSMISSIONS [Re: ChrgrCuda] #2851270
11/25/20 09:17 AM
11/25/20 09:17 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I agree. He's ok if your buying something, but if your just inquiring about something he can be unpleasant.
Re: COPE'S TRANSMISSIONS [Re: DusterKid] #2851291
11/25/20 10:24 AM
11/25/20 10:24 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Yep, he's not a fan of the fwd pattern valvebodies. He's made that abundantly clear.
'63 Dodge 330
11.19 @ 121 mph
Re: COPE'S TRANSMISSIONS [Re: GY3] #2851348
11/25/20 12:52 PM
11/25/20 12:52 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Funny reading these comments. I bought a steel planetary and some other parts to try and bullet proof my trans over the summer, about $900 worth of parts. Very pleasant on the order but when I called back with a question, a bit grouchy. lol
Re: COPE'S TRANSMISSIONS [Re: JACK1440] #2851352
11/25/20 12:55 PM
11/25/20 12:55 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I have bought 3 from him , I had a few minor problems .. but, nothing too bad ..his demeanor on the phone could use a little help . .. I get tired and grumpy too
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: COPE'S TRANSMISSIONS [Re: bigdad] #2851368
11/25/20 01:13 PM
11/25/20 01:13 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
You would thinking hearing and seeing how Indy treated guys over the years it would be a good reminder of how not to treat your customers.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: COPE'S TRANSMISSIONS [Re: pittsburghracer] #2851404
11/25/20 02:25 PM
11/25/20 02:25 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Bought 2 transmissions from him over a very long spread of time. Both were perfectly fine, and never heard a cross word from him even when I needed advise.
In fairness he does talk to mopar people all the time lol...The I need a trans that will take top fuel power, last 500 years, I have 500 bucks to spend on it gets really really old I'm sure.
Seriously, when you run a business that supports any particular hobby, the hobbyist forgets there are only 8 hours a day to make hay. Spending 5 a day on the phone to be pleasant, and make friends will run you out of business. I prefer the straight to the point guy, because I know he's more interested in working than BSing on the phone. Makes me feel like he'll get my work done.
He used to not speak to people at all during working hours, but would always get back to you the same day. I don't want anyone building anything for me getting interrupted 10 times while doing some critical thing.
Re: COPE'S TRANSMISSIONS [Re: ChrgrCuda] #2851437
11/25/20 03:56 PM
11/25/20 03:56 PM
Midwest
MoparsnMissiles Offline
Midwest
Agree with your statement, I won't purchase anything from him ever again. You should see the e-mail he sent me if you want to see the true ACEhole he is.
For the record, I had a 727 rebuilt by him a few years earlier. It is still running fine, but has developed some clunks and noises that shouldn't be there. During discussion of the second transmission I wanted him to rebuild for me, that's when the "real personality" came out.
Re: COPE'S TRANSMISSIONS [Re: MoparsnMissiles] #2851446
11/25/20 04:12 PM
11/25/20 04:12 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
OK , im going to say it again, why bash people like this. Again this is a small business and the guy cant stay on the phone all day.... ITs got to be so hard to run/produce a product and work the phone at the same time. YES i had an experience with COPE. At the time i had exploded a 727 and called him for advise/possible purchase. He was honest and explained to me that the T400 was actually a better trans for what i was going to do. NOW I KNOW THE MOPAR COMMUNITY WILL HAVE A MELTDOWN OVER THAT>>>>> but it is what it is. He explained to me that he could build a 727 that would live, but it would be more vulnerable in terms of sprag breakage with a small tire no wheelie bar car over a similar built t400. He is the on that directed me to Rossler. The man was easy to talk to and gave me some great advice. AND he made no sale.
Again, give these guys a break. The smaller businesses , they have some real challenges facing them (Covid19). YES i know customer service is number one, but in the racing specialty parts market, you need to have a balance and sometimes the product IS more important than the service. You just have to be patient
....BAD A$$ STREET CAR.....
Re: COPE'S TRANSMISSIONS [Re: n20mstr] #2851453
11/25/20 04:20 PM
11/25/20 04:20 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Tony Russo the new mayor of Moparts!
Damn bro!
Re: COPE'S TRANSMISSIONS [Re: Sammy] #2851456
11/25/20 04:30 PM
11/25/20 04:30 PM
N
n20mstr Offline
n20mstr  Offline
N
Damn bro!
Thank You !!!
Re: COPE'S TRANSMISSIONS [Re: pittsburghracer] #2851491
11/25/20 05:54 PM
11/25/20 05:54 PM
AndyF Offline
AndyF  Offline
Yeah Indy set the bar pretty high for rude behavior. But the gal at Jim's was super nasty to work with and there was a guy down south who sold restoration parts who ripped people off all the time so the Mopar hobby has plenty of cranky, rude and dishonest actors in it. I talked to Cope once about building a transmission but it was clear that he wasn't super interested in my business so I just called the next guy on my list. Not everyone likes everyone else so I just move on to someone I have a better chance of getting along with.
