need help on smoking 440 #284977
04/11/09 08:02 PM
04/11/09 08:02 PM
fresno
hyefatman Offline OP
fresno
Started break in on a fresh 440...pressure at 60 pounds and all was fine-- couple of weeks latter started motor and heard a tapping noise... sounded like a lifter- but noise went away and came back
And now is gone- but oil pressure drops to 22 pounds when oil and motor gets hot-- drivers side
exhaust is blowing blue smoke --- when i give it more gas the oil pressure goes up but I still have the blue smoke from drivers side exhaust—passenger side is clean
Re: need help on smoking 440 [Re: hyefatman] #284978
04/11/09 08:12 PM
04/11/09 08:12 PM
22 at idle & it jumps up when you goose it you're ok. I'd suspect a leaking valley pan intake gasket with a slight leak on the drivers side.
Re: need help on smoking 440 [Re: RapidRobert] #284979
04/11/09 08:20 PM
04/11/09 08:20 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Is the smoke comming out the exhaust pipe or comming off the engine?
Re: need help on smoking 440 [Re: DaytonaTurbo] #284980
04/12/09 12:08 AM
04/12/09 12:08 AM
fresno
fresno
Re: need help on smoking 440 [Re: hyefatman] #284981
04/12/09 12:11 AM
04/12/09 12:11 AM
Someplace you aren't
SomeCarGuy Online content
SomeCarGuy  Online Content
Pull the intake and pan and look for evidence of the leak that Robert pointed out might be there.
I want my fair share
Re: need help on smoking 440 [Re: SomeCarGuy] #284982
04/12/09 11:47 AM
04/12/09 11:47 AM
fresno
fresno
ok -- but would a bent push rod cause this smoke-?
Re: need help on smoking 440 [Re: hyefatman] #284983
04/12/09 12:01 PM
04/12/09 12:01 PM
A bent pushrod would only disable one cyl's power output. either the valve stems seals are bad(not likely as this eng is fresh), a bad head gasket letting oil thats going up to the valvetrain from the cam journal leak over to a cyl(extremely unlikely) or it's the tin valley pan gasket(very likely) especially w the amt of smoke & w it smoking on one bank. People install valley pans dry & have no issues but I believe the tin is not flexible enough to seal vacuum & I use permatex #2, the thick brown goo in a toothpaste tube a light EVEN coat on each side of the tin on the port openings.
Re: need help on smoking 440 [Re: RapidRobert] #284984
04/12/09 12:14 PM
04/12/09 12:14 PM
fresno
fresno
so do you think the oil- tapping noise- and blue smoke coming from the driver side exhaust are not related??
Re: need help on smoking 440 [Re: hyefatman] #284985
04/12/09 12:19 PM
04/12/09 12:19 PM
not related.
Re: need help on smoking 440 [Re: RapidRobert] #284986
04/12/09 01:39 PM
04/12/09 01:39 PM
Tapping noise could be exahust leak.
Have you pulled the intake yet?
Re: need help on smoking 440 [Re: hyefatman] #284987
04/12/09 07:45 PM
04/12/09 07:45 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
If you have a misfiring cylinder [fouled spark plug, bent pushrod, ect.] that WOULD cause blue smoke out one tailpipe.
Does the engine have a miss?
Re: need help on smoking 440 [Re: pacifica] #284988
04/12/09 08:57 PM
04/12/09 08:57 PM
fresno
fresno
yes- a small miss i am going to start working on it 2 night
Re: need help on smoking 440 [Re: hyefatman] #284989
04/12/09 10:37 PM
04/12/09 10:37 PM
How could oil be burned in a cyl that is not firing?
Re: need help on smoking 440 [Re: RapidRobert] #284990
04/12/09 11:43 PM
04/12/09 11:43 PM
fresno
fresno
update--- Took the valve covers off and noticed that one of the push rods was not under the rocker arm --- I pulled the rockers arm off and pulled put a new push rod in --- the old push rod did not look bent --- i put it back together and started the motor—it still looks like it smoking but it is hard to tell because its dark --- the miss seems to be gone .. I need to check it when I have more light--- I am curious what would cause the push rod to come out of place—I hope this is the problem
Re: need help on smoking 440 [Re: hyefatman] #284991
04/13/09 09:33 AM
04/13/09 09:33 AM
fresno
fresno
bump
Re: need help on smoking 440 [Re: hyefatman] #284992
04/13/09 12:39 PM
04/13/09 12:39 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Could be that it slipped out of position when you bolted the rockers down. Seen it happen more than once. That was your clatter that quit. If it isn't missing now drive it a bit. It may take a little time to clean out good and quite smoking.
Re: need help on smoking 440 [Re: MoparforLife] #284993
04/13/09 03:29 PM
04/13/09 03:29 PM
fresno
fresno
its is still smoking after 5 min of use-- when i give it gas the smoke seems to go away--- but comes back at idle ... i am wondering what would cause the rod to fall out if it was put in right..
any suggestions on what to do next -- i am trying to avoid pulling the head
Re: need help on smoking 440 [Re: hyefatman] #284994
04/13/09 03:34 PM
04/13/09 03:34 PM
Pull the intake
Re: need help on smoking 440 [Re: RapidRobert] #284995
04/13/09 03:42 PM
04/13/09 03:42 PM
fresno
fresno
ok - i have to pull the intake to get to the head-
but i do not think i have a intake leak- not when i found the push rod out of place- i am afaid that some thing in the head caused the push rod to fall out---
Re: need help on smoking 440 [Re: hyefatman] #284996
04/13/09 03:47 PM
04/13/09 03:47 PM
your heads are fine
