Small Block Crankshaft For Daily Driver P/U
#2849637
11/21/20 04:44 PM
11/21/20 04:44 PM
Posts: 324 Northport, al.
tvt59
Northport, al.
I don't have any experience with strokers I'll be driving this to work daily and pulling a boat in the summertime.
1st I'm thinking 4" with trick flow 190 heads 6.2 rod
2nd 4.125" Edelbrock victor heads and a 6.4 rod.
3rd 4.125" hughes big mouth heads 6.4 rods.
I don't want to have to spin it more than 7000, preferable 6500 or less.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
Re: Small Block Crankshaft For Daily Driver P/U
[Re: tvt59]
#2849652
11/21/20 05:46 PM
11/21/20 05:46 PM
Posts: 162 W. Pa
usp4u
W. Pa
Why the 6.400 rod for the 4.125 crank?
I went with a 6.200/2.000 rod on my 4.125 deal
You are gonna have a 1.096 CH even if the deck is actually 9.56. I don't like having the pin in the rings.
The Victor head will mandate a single plane....not really the best plan for towing a boat and under 6500rpm type of use.
The Big Mouth port work is likely overkill as well.
The Trick Flow is likely the better choice.
Given the intended useage, I would probably just use a ported set of RPMs.
[Re: tvt59]
#2849759
11/21/20 09:39 PM
11/21/20 09:39 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
What kind of P.U. and tranny? 1/2 ton 2 wheel drive short bed with a automatic, 1/2 ton short bed with a truck 4 speed? 3/4 ton 2 wheel drive or what? Are you wanting to mess with other trucks on the streets as far as mine is faster and more powerful than yours?
[Re: Cab_Burge]
#2849765
11/21/20 10:02 PM
11/21/20 10:02 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
You're gonna tow a boat at 7000 r.p.m. ? This , I gotta see. Figure out what it is you really want. Then call a reputable cam grinder and answer their questions. Honestly. There is nothing wrong with wanting the best of everything out of a motor. But some characteristics suffer when pursuing others. I suspect mileage is going to be a part of the equation too. Finally , a cam is just part of the picture. Select a combination of parts that compliment each other and all work toward what you want from the motor. I think you are going to find that less is more here. No need for the rotating assembly du jour here. 3.58 or 4 " with a 6.123 rod is perfectly fine.
[Re: tubtar]
#2849767
11/21/20 10:13 PM
11/21/20 10:13 PM
tvt59
Northport, al.
Big cubes need a big head. I'll probably use hyd roller. Short wb 2wd. I want to use a 4 speed auto. As far as the boat goes I'll probaby only need to tow it 4 or 5 times a year and it's only 10 miles round trip. I want a fast fun to drive P/U. I even thought about trying to find a 4.25" crank. Does anybodt make a loose converter that still has lock up capability? I know that they have them for other brands.
My Grandfather
[Re: forphorty]
#2850060
11/22/20 06:11 PM
11/22/20 06:11 PM
Posts: 4,976 new jersey usa
11secdart
new jersey usa
On the converter question… I sent the stock lockup converter from my 92 5.2 / 518 to Lenny at Ultimate he redid it and I picked up a tenth in 60 ft just saying...
[Re: 11secdart]
#2850920
11/24/20 02:24 PM
11/24/20 02:24 PM
tvt59
Northport, al.
I already have a 360 magnum block and I now have a set of Eddie heads for it. I'll consider the Lenny idea on the torque converter.
My Grandfather
