Page 4 of 6 1 2 3 4 5 6
Re: Water Wetter opinions ????? [Re: moparx] #2846993
11/16/20 12:37 PM
11/16/20 12:37 PM
central il.
second 70 Offline
second 70  Offline
central il.
Originally Posted by moparx
where did it read on both ?
beer
If you can believe it the 180 stat opened right at 180 on the stove and read just barely over half way between the H & C on my E body gauge.
Re: Water Wetter opinions ????? [Re: second 70] #2849055
11/20/20 01:08 PM
11/20/20 01:08 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Update time
Drained all the coolant, including the block drains , flushed it good with garden hose both running and not. Was super clean with no signs of crud ever
Installed a Stant super stat 180 temp thermostat in it ( it had a 160 in it I removed )
Refilled with distilled water and a bottle of Rislone cooling system additive,
Put a spring inside the lower hose
With a thermometer in the top of the radiator it shows approx 195 - 200 with the gauge showing slightly over half way.
For the most part it changed nothing other than it warms up quicker
I can hold my hand in front of the radiator and I feel it should be pulling more air thru it. I have no problem changing to a smaller diam upper pulley but at $150 or up . I would be pissed it it changes nothing.
I have heard good reviews of the milodon high flow water pump . There is room for a larger diam fan blade but finding one thats direct drive is not easy. and wonder about blade pitch if it would help or not
Thoughts
Re: Water Wetter opinions ????? [Re: gtx6970] #2849061
11/20/20 01:15 PM
11/20/20 01:15 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
PS, with the temp gauge showing a little over half, I quickly pulled the sender and stuck said thermometer in there and it showed about 210 . So its not far off what the top of the rad shows
Re: Water Wetter opinions ????? [Re: gtx6970] #2849069
11/20/20 01:43 PM
11/20/20 01:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I used a smaller pulley from a Poly 318 to speed up the pump & pan on a later RB; same bolt pattern, depth is the trick.
Blade pitch matters on aircraft prop engines & watercraft, not sure what options exist for cooling fans.
Radiator fins aren't plugged with paint/dirt/whatever, are they ?
Re: Water Wetter opinions ????? [Re: gtx6970] #2849130
11/20/20 03:19 PM
11/20/20 03:19 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Flex a lite has a 6 blade 19", also a 18" 7 blade HD fan, summit race & 4818 Flexalite worked great on my 512 ac street car, I now have dual electric,
Flex-a-lite 101571 - Flex-A-Lite 7-Blade Fans
Fan, Flex-Type, 7-Blade, Clockwise, 18.25 in. Diameter, Stainless Steel Blades/Steel Hub, Universal, Each
Part Number: FLX-4818 it moves a lot of air, That said I run the smaller water pump pulley, my car has ac
Re: Water Wetter opinions ????? [Re: CSK] #2849159
11/20/20 05:01 PM
11/20/20 05:01 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If you buy a new water pump get an Edelbrock. They have long curved blades that have a lot more surface area than the stock types. They have very little dead space, and move a lot more fluid per each revolution.
I have not seen a BB mopar Milodon water pump, but the SB ones are close to the oem design. I would not expect them to do a ton better.
Re: Water Wetter opinions ????? [Re: gtx6970] #2849181
11/20/20 06:43 PM
11/20/20 06:43 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Since you went from 50/50 coolant mix to nearly straight water with chemical wetter,
that has an effect like having a 30% gpm pump boost,
due to the greater thermal capacity of straight water.
To me that indicates the system is “airflow limited” not liquid & pump side limited.
I would now boost airflow somehow to further test.
Start by blowing more air on the parked stationary vehicle with a large electric floor fan or leaf blower.
If this added boost of airflow lowers the liquid temperature down to the 180 degree setting of the thermostat,
then try a larger diameter fan, or a same diameter fan with more blades and/or pitch.
Re: Water Wetter opinions ????? [Re: 360view] #2849206
11/20/20 07:22 PM
11/20/20 07:22 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
My thoughts as well.
The thing is it runs about same place on the gauge driving down the road at 55 mph
I cant get the idea out of my head that the fan blade is to small for the shroud opening. and/or not enough blade pitch The cars Ive had in the past you could really feel suction in front of the radiator at idle . This one IMO doesnt pull like I think it should/could. And it doesnt really help much when i bring it up off idle
Also, base timing was almost 18-19 degrees , I bumped that down to about 15 to see if it had any effect , So far nuttin
Re: Water Wetter opinions ????? [Re: gtx6970] #2849213
11/20/20 07:33 PM
11/20/20 07:33 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Ps, here is the Milodon pump. pretty good size fins that go all the way to the outer limits of the hsg
pt 16260
I would really rather not use an aftermkt aluminum fan if i can help it. simply due to looks .
Re: Water Wetter opinions ????? [Re: gtx6970] #2849225
11/20/20 07:54 PM
11/20/20 07:54 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Void space between the center hub and the blades on that design is not great. Thinkin the Edelbrock would have been a better choice even though they cost more.
Re: Water Wetter opinions ????? [Re: gtx6970] #2849227
11/20/20 08:05 PM
11/20/20 08:05 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I would say it needs more initial timing, try 22 to 25 , helps to get the heat off the cylinder walls & go out the exhaust valve
Re: Water Wetter opinions ????? [Re: CSK] #2849236
11/20/20 08:39 PM
11/20/20 08:39 PM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
I pulled the water pump off of it tonight so I have a baseline / know exactly what I have.
And its an 8 blade pump and the fins go all the way to the outer edge of the casting , just barely fits in the hsg itself . So I think its as good as Im gonna get in regards to a pump
Re: Water Wetter opinions ????? [Re: gtx6970] #2849278
11/20/20 09:50 PM
11/20/20 09:50 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
A few years ago I battled a cooling issue with my Charger and I went through the same process as you. Long story short scale/rust/crud in the block broke loose and lodged in the radiator cooling tubes, which limited flow through the radiator. I had the radiator rodded and I put in a tefba filter which solved the problem. I was surprised how much crud it captured. I talked to Gus (fourgearsavoy) a week back and he recently had a similar experience - he put in a filter and trapped a bunch of crud. If all else fails, have the radiator rodded and put in a filter (at least temporarily). twocents
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Water Wetter opinions ????? [Re: gtx6970] #2849401
11/21/20 08:05 AM
11/21/20 08:05 AM
USA
3
360view Offline
360view  Offline
3
USA
If the old water pump is now off, I personally would put the “best available” design back on, even though I would still bet the airflow enhancement is the likely final solution.
Re: Water Wetter opinions ????? [Re: gtx6970] #2849443
11/21/20 10:30 AM
11/21/20 10:30 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Bill, I don't know what blade style of fixed fan your running, but is it possible the fan's mounting is flipped or "backwards"?,....just a thought, you never know?....I've seen it before
Mike
Re: Water Wetter opinions ????? [Re: DAYCLONA] #2849457
11/21/20 10:57 AM
11/21/20 10:57 AM
It's a dry heat
gtx6970 Offline OP
gtx6970  Offline OP
It's a dry heat
Mike
It was on there correctly. And its a direct drive fixed design 7 blade
I currently have a couple friends cking for a smaller diam wp pulley.
And if can find one i would like to update to a fixed blade if i can
To speed up fan speed and coolant flow.
Re: Water Wetter opinions ????? [Re: 360view] #2849460
11/21/20 11:07 AM
11/21/20 11:07 AM
USA
3
360view Offline
360view  Offline
3
USA
If the coolant is drained and the waterpump off it would be the ideal time to snake a video boroscope into as many passages as possible to look for misplaced items like gasket material, large flakes of scale, pieces of Jimmy Hoffa, etc.
Re: Water Wetter opinions ????? [Re: Neil] #2849491
11/21/20 12:03 PM
11/21/20 12:03 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
it all comes down to air and water flow. I have seen circle track cars with the best of everything run hot. a simple hole at the rear panel let enough air flow -through- the car to drop the problem completely............ I would look hard at the shroud and fan/ locations. air flow through the radiator is most likely where your biggest gains are..........
Re: Water Wetter opinions ????? [Re: AndyF] #2849493
11/21/20 12:07 PM
11/21/20 12:07 PM
E
ek3 Offline
ek3  Offline
E
My new toy went out last night for the 1st cruise under my ownership.
1966 Satellite hemi auto 3.54 dana
And I feel the car runs a little warmer than I would prefer. right at half way up the stock gauge on the interstate. But once in stop and go traffic it warmed up a little more then I would prefer,. it,,went nearly to the top of the gauge. and spit out some coolant once parked .
The ride back home on the interstate it remained in the center of the gauge the entire drive. That I think I can live with .
I have to find out what thermostat is in it .
Car is a street hemi, auto, approx. a 18" fixed blade fan , stock radiator and shroud. the OE rad had a new 3 row core done when the car was done. But has only had maybe 1000 miles on it in 15 plus years.
I don't know yet if the block is bored or not. SO I need to do some digging. before getting to radical.
BUT, ,,,,,
My questions is, has anyone used the stuff called water wetter , results good or bad .
If I can cool it off maybe 20 degrees I would feel much better . The weather last nite was nice upper 80s for the drive up and maybe lower 80s for the drive home
If it cools fine on the freeway but not at low speed then it is probably an airflow issue. Might need a fan with more blades or perhaps the position of the fan inside the shroud needs to be fixed. Also a good idea to verify that the radiator is in good shape. If the car has been sitting a lot then the radiator core could have some plugged up passages. Cars that sit a lot develop lots of little problems like that.
rite there --- ^^^^^^^
Re: Water Wetter opinions ????? [Re: gtx6970] #2849689
11/21/20 07:12 PM
11/21/20 07:12 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I'll throw this in here; When I built my first stroker, it would heat up around town, did good on the road, but got warm at slow speeds and them would boil over from heat soak when I parked it. Annoying and embarrassing. After a lot of experimenting, I pulled a fan from (I think) an 80s Dodge pick-up. It is huge. The blades are big and have a lot of pitch to them. The problem was, of course, that it wouldn't fit in the Cuda's shroud. It would fit the clutch just fine, but was too big to go into the shroud.
Fortunately, the blades are aluminum. I just marked them, cut them down to size and installed it. That did it. It moves an enormous amount of air. I had it on that engine for several years and have now had it on this Hemi for 4 or 5 years. But it will wear out a clutch every few years, depending on the amount of driving time it gets.
The fan may not be perfectly round or in balance. But it has not given me any problems and I spin the Hemi to 7,000.
Just one experience.
Master, again and still
