Radiator question
#2848901
11/20/20 04:34 AM
11/20/20 04:34 AM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
My car has an Afco Scirocco style radiator with inlet and outlet on the passenger side and no filler neck. I would like to move my remote pump to the driver's side of the car for easier mounting of an alternator. Is there any reason I can't simply flip my radiator over so the inlet/outlet would be on the driver's side? Thanks! D
Re: Radiator question
[Re: slantzilla]
#2848938
11/20/20 09:29 AM
11/20/20 09:29 AM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
the outlet is normally 1.75" and the inlet is 1.5" so you would need to deal with that, the drain will now be on top.
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2849077
11/20/20 01:56 PM
11/20/20 01:56 PM
slantzilla
Park Forest, IL
Both ports are 1-1/4", but I forgot about the drain.
Thanks!
[Re: slantzilla]
#2849085
11/20/20 02:08 PM
11/20/20 02:08 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
The drain becomes a vent for filling, and you can just pull the hose to drain it.
68 Barracuda Formula S 340
[Re: Bad340fish]
#2849202
11/20/20 07:21 PM
11/20/20 07:21 PM
slantzilla
Park Forest, IL
Good idea! The more I think about it, it may have a plug in the top of it where a drain would go if I flip it over. I gotta look next time I go down to my shop. Thanks!
