An Organisol Adventure
#2848552
11/19/20 10:56 AM
11/19/20 10:56 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
In the middle of a much larger project and thought I'd post....Maybe this will help somebody out.
I wanted to get as close to the OE 69 1/2 A12 hood paint as I could, without turning it into a lifelong pursuit, and without paying a shop $1000+, without going to the resto guru for $800 worth of paint, or anything like that. I do realize they varied from car to car somewhat, but there was a certain texture I'd seen on show vehicles + untouched original cars that I was after.
SEM hot rod black, PN HR010 has good reviews on Amazon + a good shot of an an a12 style hood and that convinced me to try it. (I got my best price somewhere other than Amazon. Shop carefully.) It got me about as close as I will likely ever get.
This is 2k primer sanded to P320. (You can go finer if you want, but the following steps more than hide any sanding scratches 2x over)
Rich H.
Esse Quam Videri
Re: An Organisol Adventure
[Re: ZIPPY]
#2848553
11/19/20 10:58 AM
11/19/20 10:58 AM
ZIPPY
S.E. Michigan
Sealed with one wet coat of black epoxy primer, reduced around 15%.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2848554
11/19/20 11:01 AM
11/19/20 11:01 AM
ZIPPY
S.E. Michigan
"Epoxy as sealer" sat for 2 hours.
Shot two wet coats of SEM hot rod black over that, per the instructions.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2848559
11/19/20 11:10 AM
11/19/20 11:10 AM
ZIPPY
S.E. Michigan
After overnight cure.
Side comment: This is very close to the appearance of my untouched original '68 Charger tail panel (which is the only original example of Organisol that I've owned). It was very slightly flatter than this and did not have any texture.
I stopped here for a day while deciding what to do. It looked pretty good to me, I could have stopped right here.
But it wasn't quite "the look".
Eventually I decided that the texture is kind of important to the look of an A12-type hood, and if that's what I am gonna do, I should experiment a little and see if I can get there.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2848568
11/19/20 11:28 AM
11/19/20 11:28 AM
ZIPPY
S.E. Michigan
Closeup of the texture. I'm pretty happy with it.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2848571
11/19/20 11:32 AM
11/19/20 11:32 AM
ZIPPY
S.E. Michigan
An original. (Love this).
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2848574
11/19/20 11:41 AM
11/19/20 11:41 AM
ZIPPY
S.E. Michigan
Summary......
Overall mine is definitely on the heavier textured side, which I'd seen on alot of show vehicles and really loved. Nice to figure out how to.....if not duplicate it, at least do my own version of it.
You have total control of how much texture you get in the last step. If you want a little less texture than this, I would suggest try increasing the distance between the gun and the panel. The important thing is to practice until you get the gun and your technique where you want it, before shooting the actual hood.
Pretty satisfying.
Maybe this will help someone out.
All for now...
Rich H.
Esse Quam Videri
[Re: DynoDave]
#2890074
02/18/21 02:06 PM
02/18/21 02:06 PM
ZIPPY
S.E. Michigan
Thanks Dave!
Alot more extensive work to the rest of the car is going on right now, I've been working on it quite a bit...the hood looks pretty good hanging on the wall.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2893208
02/25/21 09:54 PM
02/25/21 09:54 PM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
A lot more extensive work to the rest of the car is going on right now, I've been working on it quite a bit...the hood looks pretty good hanging on the wall. And where is THAT build thread at?
[Re: DynoDave]
#2893459
02/26/21 04:59 PM
02/26/21 04:59 PM
ZIPPY
S.E. Michigan
It's an album on my Fakebook.
Not just pictures and text, but also video with verbal descriptions and so on.
Maybe someday I should diversify and dump some of the material here and on FBBO.
Been suggested I should start a youtube channel, but not sure if I have the energy to put into it.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2893560
02/26/21 11:33 PM
02/26/21 11:33 PM
DynoDave
MICHIGAN
I've sort of walked away from facebook for the time being. I do follow a few folks on YouTube, but not a lot. I'd love to see some of that content here on Moparts. In your spare time!
