Stock coil or should it be changed? Points to Electroni #284832
04/11/09 04:41 PM
04/11/09 04:41 PM
USA
Suregrip391 Offline OP
USA
I plan to install a Mopar Performance electronic ignition setup on my 1970 Satellite, 383 engine that still has the stock point type distributor in it. My question is, will I need to buy a new coil or can I use the old existing one? I thought I read it needed to be changed for one compatible with electronic ignition? If so, Can I just get one from a 73 Chrysler or something that originally had electronic ignition or will I need a performance one? What do you guys recommend? This is not a race car, just a sunday cruiser...stock 383 with a 2-bbl. Thanks!
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284833
04/11/09 04:59 PM
04/11/09 04:59 PM
your same coil will work you are now just switching it's primary off/on electronically instead of mechanically. I'd get the 1.25 ohm ballast & I would highly suggest that you get the MP chrome box instead of the orange ecu even if it means you buy the dist/harness/ecu seperately instead of the orange box complete pkg. EDIT if you do change coils yes a 73 up stock one will be fine as you would have exactly the same as a factory oe 73 up setup but unless you had one in your stash you might get a hotter one such as a msd blaster 2(which MAY change the ballast requirements) but your stock coil will work fine.
Re: Stock coil or should it be changed? Points to Electroni [Re: RapidRobert] #284834
04/11/09 05:30 PM
04/11/09 05:30 PM
USA
USA
The Mopar kit comes with a new ballast, do you think its the 1.25 ohm? I'm not sure which ohm ballast is currently on my car, I would assume a stock one. Just trying to set myself up with all the right parts while waiting for my kit to show up.
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284835
04/11/09 05:40 PM
04/11/09 05:40 PM
The Mopar kit comes with a new ballast, do you think its the 1.25 ohm? Just trying to set myself up with all the right parts while waiting for my kit to show up.
(1) yes (2) You have the orange box(kit) ordered?
Re: Stock coil or should it be changed? Points to Electroni [Re: RapidRobert] #284836
04/11/09 05:56 PM
04/11/09 05:56 PM
USA
USA
Yes, it comes with the orange box. I am buying a set from a member here, its new in the box, never used.
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284837
04/11/09 06:28 PM
04/11/09 06:28 PM
The odds are very high that you wont have a single issue with the orange box.
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284838
04/11/09 09:19 PM
04/11/09 09:19 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
While updating the ignition, consider the following:
1. Upgrade to the chrome box
2. Upgrade to the Mopar Blaster coil
3. Upgrade ballast resistor to 0.25 Ohms
Next when setting the timing, note that the Mopar distributor has 20 degrees and you should set the inital advance @ 14-16 degrees. Making a total of 34-36 degrees.
Just my $0.025..
Re: Stock coil or should it be changed? Points to Electroni [Re: Sinitro] #284839
04/11/09 09:22 PM
04/11/09 09:22 PM
USA
USA
Just my $0.025..
Did you mean 1.25 ohms? The one that comes with the kit from Mopar Performance?
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284840
04/11/09 09:33 PM
04/11/09 09:33 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
The electronic kit comes with a 1.25 Ohms but when you use a Mopar Blaster coil (Mopar #4876732), you use a 0.25 Ohms (Mopar #2444641). Because the Blaster has higher output voltage and can handle a higher input voltage, when using a 0.25 Ohm vs the 1.25 Ohms the coil sees a higher voltage.
Just my $0.025..
Re: Stock coil or should it be changed? Points to Electroni [Re: Sinitro] #284841
04/11/09 10:15 PM
04/11/09 10:15 PM
USA
USA
Just my $0.025..
Thanks for the help, just to clarify, if using the stock point type coil currently on my car, just use the 1.25 OHM resistor that comes with the kit, if I use the Mopar Blaster coil, use the .25 ohm resistor. The purpose of the Mopar blaster coil and .25 ohm resistor is for a hotter spark? Better performance? As mentioned, this car is all stock, 2-brl carb, 383, automatic. Not a race car by any means.
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284842
04/11/09 10:34 PM
04/11/09 10:34 PM
(1)yes (2) yes (3)yes,hotter spark/better performance
Re: Stock coil or should it be changed? Points to Electroni [Re: RapidRobert] #284843
04/11/09 10:39 PM
04/11/09 10:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
In a bone stock 2bbl 383 car I doubt you'll feel any difference between the blaster and the stock coil. I put one on a smogger 440 once, which you would think would need all the spark help it could get, and it made no difference on my seat-o-pants meter.
Re: Stock coil or should it be changed? Points to Electroni [Re: DaytonaTurbo] #284844
04/11/09 10:42 PM
04/11/09 10:42 PM
was that with using the the .25 ballast
Re: Stock coil or should it be changed? Points to Electroni [Re: Suregrip391] #284845
04/11/09 11:30 PM
04/11/09 11:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd avoid the "el crapo" Chrysler Electronic Ignition,....IMHO your much better off with a Pertronix Ignitor II set-up and coil,....eliminate the ballast in the set-up,
in the Pertronix conversion you get to keep your original point distributor, just install the coversion kit, everything fits under the stock cap......
Re: Stock coil or should it be changed? Points to Electroni [Re: DAYCLONA] #284846
04/11/09 11:44 PM
04/11/09 11:44 PM
!!!REALLY!!! I guess the hundreds of thousands of Chryslers that ran for hundreds of thousands of miles using the el crapo Chrysler ignition were just, lucky?
I put on of these in my '70 soon after they came out in, when, 72? I owned that car up into the '80's. Later, I ran a 340 in my old FJ40 Landcruiser, and guess what? I ran an el crapo Chrysler ECU in that too!! Last time it ran, it ran with the el crapo ECU
Re: Stock coil or should it be changed? Points to Electroni #284847
04/12/09 12:26 AM
04/12/09 12:26 AM
Manitoba, Canada
Manitoba, Canada
Yeah but why add in all the extra wiring and clutter when the pertronix will keep it clean, simple and stock looking and do just as good of a job at it?
Re: Stock coil or should it be changed? Points to Electroni [Re: DaytonaTurbo] #284848
04/12/09 12:48 AM
04/12/09 12:48 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would not use a .25 ohm ballast resistor, if your going to use a Mopar/MSD blaster coil use the msd .85 ohm ballast its a super heavy duty one, if you get the coil it might come with one, the MSD blaster i got 15 years ago had on in the package and its still on the car. And also use some washers behind it to raise it off the firewall so it will have some air movement behind it.
Re: Stock coil or should it be changed? Points to Electroni [Re: ademon] #284849
04/12/09 11:49 AM
04/12/09 11:49 AM
Northeast
mopar71RR Offline
mopar71RR  Offline
Northeast
Did you mean to replace the MP resistor(1.0 ohm) with the MSD .85 resistor??
Re: Stock coil or should it be changed? Points to Electroni [Re: mopar71RR] #284850
04/12/09 12:14 PM
04/12/09 12:14 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
I would not use the .25 ohm resistor it will give more spark but i don't think one that low is recomended for a street car, it may overheat the coil. the 1.0 ohm mopar would be fine, i like the MSD .8 ohm, its just a heavy duty looking resistor i dont think you would see any seat of the pants dif between the mopar 1.0 & the MSD.
Re: Stock coil or should it be changed? Points to Elect [Re: Suregrip391] #284851
04/12/09 12:42 PM
04/12/09 12:42 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
you don't need to worry about ballast resistors or coils. i would just install the electronic conversion kit as is. it already comes with everything you will need. i don't think you need a hotter spark than stock as you said it is a sunday cruiser with a stock 2bbl 383. electronic ign. is a smart upgrade.
