235/60R15 is equivalent to G60x15.
215/60R15 is equivalent to the E60X15s that would have been factory on that car.
most conversion sites & the math will show
245/60R15 is close to G60x15.
225/60R15 is close to E60X15
tire construction & manufacturer all have different spec's for the same size tire
even Kelsey Tire's reproduction POLYGLAS tires are not all identical dimensionally to what was original equipment
215/60R15 by BFG 25.2" diameter & 8.7" section width
225/60R15 by BFG 25.6" diameter & 9.0" section width
E60X15 by Kelsey 26.1" diameter & 8.9" section width
