Re: Carb soaking recommendations
[Re: Lugnutz]
#284620
04/11/09 03:21 PM
04/11/09 03:21 PM
RapidRobert
Sounds like they are real grungy. I'd take them apart as is & throw everything in the soup. Only Q is how long you plan to keep them in there. I kept my eddie in there for several days(I got sidetracked)& the exterior finish looked good ex the big edelbrock sticker on the front came off which didn't bother me & others have stated that anymore than a half hour that the outside finish on their Holley was ruined. I've had some holleys w the orig type gaskets that took alot of soaking to soften the gasket material up.
[Re: JimG]
#284622
04/11/09 07:15 PM
04/11/09 07:15 PM
Posts: 30,473 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
I would think the plan is .. is to scrape and clean the carb off before putting it into any chemical so not to contaminate it. This Berryman chem ? ...were is it available ? .. pricey? .. how so? .. There was some stuff up here at Napa .. 4 gallons or so ... 125$ ...IIRC .. Does it clean the alum well? ... down-to the stains and tarnish ?
[Re: 68CoronetRT]
#284624
04/11/09 07:49 PM
04/11/09 07:49 PM
Posts: 7,545 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I bought a lesser amount of carb cleaner in a small bucket from NAPA - about $50 worth (1 gal IIRC) and it works fine for bathing carb parts after disassembly. Yes, it did take the cadmium plating off when I left parts in more than a couple hours. Otherwise it worked well. Nasty for your health tho.
Hemmings Muscle Machines reviewed a new bathing chemical this month that sounded good (plus more enviro and health friendly). Might try it when my current batch of NAPA chemical goes bad.
- Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: dOc !]
#284625
04/11/09 09:06 PM
04/11/09 09:06 PM
I've purchased the berryman stuff in 1 gal cans at Murray's, now O'riley's, for around $15-$20 IIRC...
Side note: Berryman's stinks like a sumbich!!! Smells like concentrated bandaid stink.
#284626
04/12/09 01:40 AM
04/12/09 01:40 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
I purchased a 1 gallon can of Berryman's but wasn't able to fit the main body of a small Holley 4 barrel in it. I was able to soak the bowls and metering plates but had to clean the main body with a can of carb cleaner.
[Re: Lugnutz]
#284627
04/12/09 09:02 AM
04/12/09 09:02 AM
Posts: 531 Virginia
JimG
Virginia
I bought my 5-gallon pail of Berryman Chem Dip at O'Reilly for $69.99. After reading some other replies, perhaps it wasn't as pricey as I thought. http://www.berrymanproducts.com/Default.aspx?tabid=146I tried some Gunk cleaner that didn't do very much. As previously noted, you can't get an entire carb into a 1-gallon pail of the stuff, and if you pour it into a larger container, the carb is basically sitting in a shallow puddle of cleaner. A 1 gallon pail will do nothing but frustrate you. Wear good quality chemical gloves when you mess with this concoction - it'll dry your hands out like nobodies business. And as previously noted, the stench is enough to knock a buzzard off a gut wagon! Jim
[Re: JimG]
#284629
04/12/09 02:53 PM
04/12/09 02:53 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Don't know how it is in Canada but here in Cali (EPA) we cannot get the good Berryman stuff. That stuff made in the 70s work like a modern dishwasher on dirty plate. The stuff we get here now is like using a 70s dishwasher on a dirty plate!
I think I paid $45-70 back in the early 80s for a 5 gal bucket.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#284630
04/12/09 02:58 PM
04/12/09 02:58 PM
Posts: 6,516 Santa Cruz, California
Lefty
I wondered why my new can didn't work as well as the 30 year old gallon I finally retired. Still stinks bad though!
[Re: cdp]
#284631
04/12/09 02:58 PM
04/12/09 02:58 PM
RapidRobert
A person could get by with a gallon & set the carb bowl in a old pan & pour the soup in the carb bowls(where it'd do the most good) getting into the passages & use a bristle brush for the venturi's & the exterior.
