Re: 8 3/4 posi gear oil
[Re: Howard]
#284606
04/11/09 01:05 PM
04/11/09 01:05 PM
Posts: 1,101 Retired now in Tennessee
Chi_Town_Runner
Howard, Here are some quotes from a previous post. I have no personal expierence but I kept these for when I get ready to do my gear. Quote:
Differential additive
70Duster440 said "The local Ford dealer had the LS additive that worked for me. The smell alone will choke an elephant."
Cuda340 said "Get the ford friction modifier as listed and then stop at Walmart for the Supertech 85-140 Gear lube..."
In_The_Pink said "The additive comes in a 10 or 12 oz squeeze tube and you add the entire contents. Fill the diff until it starts to flow out of the filler hole."
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
[Re: Howard]
#284607
04/11/09 03:35 PM
04/11/09 03:35 PM
RapidRobert
I'd get 85-140 & a small bottle of that whale oil additive
[Re: dOc !]
#284611
04/12/09 09:25 AM
04/12/09 09:25 AM
Posts: 7,506 Az
Crizila
Az
Auburn Gear does not recommend synthetic gear lube in their cone type posi units. I guess it's too slickery. 80w-90 GL5 is all they recommend. Any friction modifier will work at a ratio of 3oz to every 1qt of gear oil. Minumum breakaway torque = 20 lb ft. Less than that it's rebuild time. new unit = 80-100lb ft.
Fastest 300
[Re: Crizila]
#284612
04/12/09 09:29 AM
04/12/09 09:29 AM
Posts: 7,506 Az
Crizila
Az
- and on that friction modifier thing, you want just enough in there so the diff doesn't chatter around corners. More than that just defeats the purpose of having a posi unit.
Fastest 300
