Re: EDELBROCK Electric Choke (vacuum port question)
[Re: wally426ci]
#2845900
11/13/20 09:22 PM
11/13/20 09:22 PM
Posts: 15,315 Omaha Ne
TJP
Omaha Ne
[Re: TJP]
#2845902
11/13/20 09:28 PM
11/13/20 09:28 PM
Posts: 6,229 nowhere
Sniper
nowhere
Not sure what carb that is, other than not an Edelbrock one. In this article https://www.hotrodhotline.com/conte...barrel-jim-clark-hot-rod-md#.X68zjhZ7mM8It states "Vacuum from beneath the venturi in the carburetor has drawn the piston down in the choke housing keeping the choke butterfly open once the engine has reached operating temperature." Doesn't sound like it should be a vacuum leak. If I remember I;ll look at my carb tomorrow and see if it's open or sealed.
[Re: B1MAXX]
#2846021
11/14/20 10:03 AM
11/14/20 10:03 AM
Sniper
nowhere
That's supposed to draw warm air into the choke housing to help speed warm up. Some people used to attach 1/4 copper tubing to it and wrap it around a header tube back in the day. Some even used to sell a kit that clamped to a header tube with a couple of hose clamps. Some gm app.'s connect that to an EGR port. Not supposed to draw warm air at all. Go read the Edelbrock instructions.
[Re: 4406bbl]
#2846114
11/14/20 03:07 PM
11/14/20 03:07 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Pretty sure you want to leave that open to draw ambient temperature air across the heater coil so the choke stays on more cold, less when hot. The vacuum at the open port is from the piston which is not 100% sealed to its bore, the piston pulls the choke blade open and the residual vacuum pulls in fresh air to keep the heated coil from overheating.
