1971 Satellite-Adding A Sway Bar #2844988
11/11/20 05:40 PM
11/11/20 05:40 PM
Oak Forest, Texas
markshemiworld Offline OP
Oak Forest, Texas
Does anybody know of what sway bar to order for a 1971 Satellite? Car has been cloned into a roadrunner and is just a driver but has upgraded shocks, torsion bars, tubular control arms, but no sway bar. Car is never raced, just looking to improve cruising on the street. Hoping to get one that doesn’t require drilling and just uses the front shock mount.
Thanks ahead of time!
Re: 1971 Satellite-Adding A Sway Bar [Re: markshemiworld] #2845005
11/11/20 06:28 PM
11/11/20 06:28 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
I would contact firm feel and tell them what you have for a setup.
Do your lower control arms already have sway bar brackets on them?
http://www.firmfeel.com/b_body_mopar_front_sway_bar.html
Re: 1971 Satellite-Adding A Sway Bar [Re: skdmark] #2845008
11/11/20 06:33 PM
11/11/20 06:33 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Firm Feel x2.
Mike.
Re: 1971 Satellite-Adding A Sway Bar [Re: moparmike1] #2845052
11/11/20 08:22 PM
11/11/20 08:22 PM
Oak Forest, Texas
Oak Forest, Texas
I checked out their page and it’s looking like $400 before tax and shipping. Seems a little high to me, but maybe I’m uninformed. Is $400 what I should expect to add a sway bar to a stock/street car?
Thanks!
Re: 1971 Satellite-Adding A Sway Bar [Re: markshemiworld] #2845124
11/11/20 10:11 PM
11/11/20 10:11 PM
ILL
Greentween Offline
Greentween  Offline
ILL
Go to summit, look up your car, chassis and suspension and the brands would be Addco or Hellwig.
Re: 1971 Satellite-Adding A Sway Bar [Re: markshemiworld] #2845227
11/12/20 10:39 AM
11/12/20 10:39 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Firm Feel will have units that most closely duplicate or are carbon copies of stock and may require you add brackets to the lower control arm. Some lower priced aftermarket units do not duplicate exact stock layout and attach to the lower shock bolt with an angle bracket and have various stacks of plates to attach to the K frame. Depends on how original you want it to be.
Re: 1971 Satellite-Adding A Sway Bar [Re: TC@HP2] #2845260
11/12/20 11:52 AM
11/12/20 11:52 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I got my bar from Rock Auto. No longer listed. The PST GMax bar is $219. 1 1/8” bar
Abe Lincoln
Re: 1971 Satellite-Adding A Sway Bar [Re: markshemiworld] #2845266
11/12/20 12:00 PM
11/12/20 12:00 PM
AndyF Offline
AndyF  Offline
I've used a few Hellwig bars over the years. They usually fit okay and the price is right.
https://www.hellwigproducts.com/pro...71&Make=Plymouth&Model=Satellite
Re: 1971 Satellite-Adding A Sway Bar [Re: AndyF] #2845825
11/13/20 06:10 PM
11/13/20 06:10 PM
GA
roadrunninMark Offline
GA
Hellwig bar/kit also has the bolt on (or weld if you want) tabs for your lower control arms if yours do not have them.
Re: 1971 Satellite-Adding A Sway Bar [Re: roadrunninMark] #2845877
11/13/20 08:25 PM
11/13/20 08:25 PM
Essex, Ont., Canada
Fishmarket Offline
Fishmarket  Offline
Essex, Ont., Canada
hellwig 55904 from sdtrucksprings.com $176.77
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
