if you have aluminum heads the general rule is .006 tighter when cold.
Start it up and let it warm up so it is at least as hot as 180F and then quickly check one side to see how much it loosens up warm and go from there
I've had some motors that works well on and other that it didn't
Hemiroid motors have their own quirks and rules that don't always follow the rest of the pack
I have always tighten the lash up from .004 to .012 on all the old loose lash cams like Direct Connection, Racer Brown, Isky, Clay Smith and many other company use to sell
I use the lash for tuning, test, test and test some more
