New Gas Tank leak #2843567
11/08/20 05:59 PM
11/08/20 05:59 PM
own private Idaho
N
ngpSatellite Offline OP
N
own private Idaho
Replaced my Gas tank and can't seem to get the filler neck grommet seal to Seal... Do you use a certain RTV? or even use RTV.. any tips would be great.
Re: New Gas Tank leak [Re: ngpSatellite] #2843573
11/08/20 06:10 PM
11/08/20 06:10 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
No RTV! Will be a major failure.
Make sure its super clean and lubricate seal with silicone during assembly.
Re: New Gas Tank leak [Re: markz528] #2843578
11/08/20 06:18 PM
11/08/20 06:18 PM
own private Idaho
N
N
own private Idaho
ok... any particular silicone brand?
Thanks for the help!
Re: New Gas Tank leak [Re: ngpSatellite] #2843585
11/08/20 06:28 PM
11/08/20 06:28 PM
Kirkland, Washington
Pacnorthcuda Offline
Vaseline works.
Re: New Gas Tank leak [Re: Pacnorthcuda] #2843594
11/08/20 07:00 PM
11/08/20 07:00 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Originally Posted by Pacnorthcuda
Vaseline works.
I agree. Use Vaseline instead of silicone. When I said silicone I meant just silicone spray lubricant. I just used silicone but Vaseline would be better..............
Re: New Gas Tank leak [Re: Pacnorthcuda] #2843597
11/08/20 07:04 PM
11/08/20 07:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I use plumber's silicone grease from Ace Hardware but for some reason I can't get it to come up on their website.
Re: New Gas Tank leak [Re: 6PakBee] #2843641
11/08/20 08:37 PM
11/08/20 08:37 PM
own private Idaho
N
N
own private Idaho
Thanks for all the advise! Much Appreciated
Re: New Gas Tank leak [Re: ngpSatellite] #2843731
11/09/20 12:39 AM
11/09/20 12:39 AM
IMGTX Offline
IMGTX  Offline
Make sure the neck is clean and smooth. Some necks have undercoat or dirt on them and won't seal well when re-positioned.
I use a thin smear of bearing grease to let the neck slide in smoothly. You should not need a sealant. Gas eats RTV, bearing grease and just about everything over time so just enough to lubricate the slide in is all you should need.
Did you get a new seal? Does it fit the neck snugly? There was a run of bad seals a few years back IIRC.
Re: New Gas Tank leak [Re: IMGTX] #2843794
11/09/20 07:46 AM
11/09/20 07:46 AM
own private Idaho
N
N
own private Idaho
I replaced the seal... bought on ebay frown it was leaking pretty bad... when I took it apart to see why, the seal shrunk and was almost egg shaped and an 1/8 of an inch shorter then the next one I just put on. I just ordered one from Detroit Muscle.. hopefully there good...
Re: New Gas Tank leak [Re: ngpSatellite] #2843931
11/09/20 11:31 AM
11/09/20 11:31 AM
IMGTX Offline
IMGTX  Offline
At one time I would order a new seal from mopar but for a late 80's early 90's truck. It was a little different looking but fit fine. They may be NS1 by now.
I feel confident the Detroit Muscle ones will be good.
Re: New Gas Tank leak [Re: IMGTX] #2843943
11/09/20 11:47 AM
11/09/20 11:47 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Yes, try and get a mopar seal. Some of the aftermarket ones are junk. I`m not sure what year you are working with but 4002010 fits quite a few years and is still available.
Re: New Gas Tank leak [Re: markz528] #2844133
11/09/20 05:10 PM
11/09/20 05:10 PM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
IMO silicone is the most logical but worst thing you can use. Get that stuff on metal or paint, and it's basically there forever. Get it on your hands and touch something, same thing. DAMHIK.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
