Re: Voltage Gauge is all over the place. Any suggestio
[Re: stumpy]
#284235
04/11/09 10:49 AM
04/11/09 10:49 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Don't think he's got an ammeter anymore.
Based on your symptoms, which are endemic to old MoPars, your problem is bad connections.
The bulkhead connector is the usual suspect.
also, just because you have an 80A alternator doesn't mean you have 80A, especially at idle.
I would clean the bulkhead connections, rewire the lights and fan so that a relay connects them to the battery and the only power going thru the bulkhead connector is the control voltage to switch those relays.
To be honest I'd throw the electric fans in the trash.
Next, try to get a spec sheet for your alternator, if you aren't turning it fast enough at idle nothing will help. You may have to juggle pulley sizes.
The farther you stray from stock the more engineering YOU have to do.
[Re: Cudalord]
#284244
04/11/09 06:23 PM
04/11/09 06:23 PM
Posts: 7,664 IN
ahy
IN
What is the GM or Denso style alternator that I can upgrade to? Do you have any part numbers? Is it a direct swap?
THanks!
Check Mancini's websight under lighweight alternator packages. There's a 120 Amp Denso package there.
