Torque converter squeaking #283969
04/10/09 06:44 PM
04/10/09 06:44 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Finally traced my mysterious squeak. I jacked the car up, put in gear and had my wife sit in the car with her foot on the brake. As soon as you put the car in a forward gear a rather large squeak comes from the torque converter. Doesnt do it in N and doesnt seem as loud in R.
Any ideas?
Gonna pull it in and pull the tranny back.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Torque converter squeaking [Re: Von] #283970
04/10/09 06:46 PM
04/10/09 06:46 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
either the flex plate is cracked or the bolts backed out on you
1.39 9.85 - 137 mph
Re: Torque converter squeaking [Re: Ari440] #283971
04/10/09 08:03 PM
04/10/09 08:03 PM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
I had a converter bolt back out on me and thought it was a rod knock!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Torque converter squeaking [Re: hemi-itis] #283972
04/10/09 09:28 PM
04/10/09 09:28 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
We had a converter go bad a long time ago in a 340 Roadrunner, it sounded like the car had a loud gear drive in it.
Re: Torque converter squeaking [Re: ProSport] #283973
04/10/09 09:57 PM
04/10/09 09:57 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yes a bad converter can sound a lot like that when in gear.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Torque converter squeaking [Re: dusturbd340W5] #283974
04/10/09 10:25 PM
04/10/09 10:25 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Pulled it all apart and everything checks out OK. Checked crank end play and it is OK also.
Anyway to determine it might be the converter without sending it off?
Any other ideas?
Re: Torque converter squeaking [Re: Von] #283975
04/11/09 12:05 AM
04/11/09 12:05 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
All you can do is stick your finger in the converter and see if everything turns free'ly and look for broken pieces or metal shavings. Best bet is to send it out while it's out of the car and it's early in the season.
Re: Torque converter squeaking [Re: Von] #283976
04/11/09 01:28 AM
04/11/09 01:28 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I had one that started making a squeek or chirp when I put it in gear . It was definately the converter. The 60' were a 1/2 second off. The car would just fall on its face out of the hole.
Re: Torque converter squeaking [Re: super451b] #283977
04/11/09 07:40 AM
04/11/09 07:40 AM
Q
Quicktree Offline
Quicktree  Offline
Q
better hope it's not a bearing in the motor. I have seen that a few times.
Re: Torque converter squeaking [Re: Quicktree] #283978
04/11/09 07:52 AM
04/11/09 07:52 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I had a whine... sounded something like a supercharger as I recall. THe bearing in the convertor had come apart. Only way to tell (fluid was clean, no metal or damage visible) was the noise, and the brake stall was not consistent. Bottom line, it if's noisey, and it wasn't, and evrything else is fine, then it's the convertor.
Re: Torque converter squeaking [Re: Quicktree] #283979
04/11/09 09:09 AM
04/11/09 09:09 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Yep,spun rod bearing makes that kind of noise..AMHIK!!
Nautilus Racing-
Re: Torque converter squeaking [Re: Chris2581] #283980
04/11/09 11:26 AM
04/11/09 11:26 AM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Found the problem or lack thereof after 8 hours of wrenching. Turns out it was the slip tube on my passenger header vibrating....
Re: Torque converter squeaking [Re: Von] #283981
04/11/09 12:37 PM
04/11/09 12:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You sure... could be the rocker you found without
oil
Re: Torque converter squeaking [Re: MR_P_BODY] #283982
04/11/09 08:49 PM
04/11/09 08:49 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
oil
Positive. The rocker arm is a new problem since I pulled the whole shaft and rockers off on Thurs and they were fine then.
