Torque converter squeaking
#283969
04/10/09 06:44 PM
04/10/09 06:44 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Finally traced my mysterious squeak. I jacked the car up, put in gear and had my wife sit in the car with her foot on the brake. As soon as you put the car in a forward gear a rather large squeak comes from the torque converter. Doesnt do it in N and doesnt seem as loud in R.
Any ideas?
Gonna pull it in and pull the tranny back.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Torque converter squeaking
[Re: dusturbd340W5]
#283974
04/10/09 10:25 PM
04/10/09 10:25 PM
Von
NE Oklahoma
Pulled it all apart and everything checks out OK. Checked crank end play and it is OK also.
Anyway to determine it might be the converter without sending it off?
Any other ideas?
[Re: Von]
#283975
04/11/09 12:05 AM
04/11/09 12:05 AM
Posts: 17,924 Akron, Ohio
ProSport
Akron, Ohio
All you can do is stick your finger in the converter and see if everything turns free'ly and look for broken pieces or metal shavings. Best bet is to send it out while it's out of the car and it's early in the season.
[Re: Quicktree]
#283978
04/11/09 07:52 AM
04/11/09 07:52 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
I had a whine... sounded something like a supercharger as I recall. THe bearing in the convertor had come apart. Only way to tell (fluid was clean, no metal or damage visible) was the noise, and the brake stall was not consistent. Bottom line, it if's noisey, and it wasn't, and evrything else is fine, then it's the convertor.
[Re: Chris2581]
#283980
04/11/09 11:26 AM
04/11/09 11:26 AM
Von
NE Oklahoma
Found the problem or lack thereof after 8 hours of wrenching. Turns out it was the slip tube on my passenger header vibrating....
[Re: Von]
#283981
04/11/09 12:37 PM
04/11/09 12:37 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You sure... could be the rocker you found without oil
[Re: MR_P_BODY]
#283982
04/11/09 08:49 PM
04/11/09 08:49 PM
Von
NE Oklahoma
Positive. The rocker arm is a new problem since I pulled the whole shaft and rockers off on Thurs and they were fine then.
