Edlebrock Magnum head
#2838859
10/29/20 04:04 PM
10/29/20 04:04 PM
Posts: 324 Northport, al.
tvt59
Northport, al.
My brother is doing a 408 street car build for himself. For his birthday I think I'm going to send his heads out and get them ported for him. Was thinking about sending them to Hughes and have their big mouth port job done on them.
A. Does anyone have experience with this version of Hughes heads.
B. Does someone else have a better program for these heads.
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
Re: Edlebrock Magnum head
[Re: tvt59]
#2838868
10/29/20 04:17 PM
10/29/20 04:17 PM
Posts: 12,404 Taxes & Virus's R-US, NY
Dragula
I would call around to some of the Mopar shops and get some quotes, and then pick who you feel comfortable with. Unfortunately, I am not up on who can port the small block heads except Shady Dell, and he, as far as I know, is out of business. So take a look at your budget and your goals and see where that puts you...You can always do a cleanup and gasket match yourself with some simple tools and go from there.
[Re: Dragula]
#2838875
10/29/20 04:49 PM
10/29/20 04:49 PM
tvt59
Northport, al.
Ryan did a complete W5 small block engine for me . I'm very happy with it. But I have not been able to contact him in the last year or so. Thanks for your replay.
My Grandfather
[Re: tvt59]
#2839040
10/29/20 10:05 PM
10/29/20 10:05 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
We usually step up to a 2.055 intake valve, porting, valve job, surface cut, seals and setup on springs runs around 1350.00 with the valves. Brian immengine@yahoo.com
Brian Hafliger
[Re: tvt59]
#2840880
11/02/20 07:05 PM
11/02/20 07:05 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I've been to Hughes' shop and had him do some work for me.. he has a CNC machine programmed for porting different heads... in fact, he does heads for other shops ... using his CNC equipment. If you go with him, just be patient as his work load builds up ... get in line ... sooner the better.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: tvt59]
#2841098
11/03/20 08:32 AM
11/03/20 08:32 AM
Posts: 4,689 On the parachute mount
n20mstr
Thanks Brian at IMM , he did a set for my son. Unreal !! On a ballhoned 360 magnum with flattops. The car has been 11.12 at 123 !! On pump gas. He responded a few posts above. Contact him ! ! ! The only reason we havent been in the tens yet is , the car has no roll bar and a few tracks have told him NO MORE....LOL. I can wait to see what i runs with a little nitrous
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2841523
11/04/20 01:14 AM
11/04/20 01:14 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Damn that's awesome. N20mstr can you give more info about your sons engine?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#2841578
11/04/20 08:40 AM
11/04/20 08:40 AM
n20mstr
Damn that's awesome. N20mstr can you give more info about your sons engine? Nothing crazy. a Magnum that we ballhoned. He got a flattop forged piston.(standard bore) We figure the comp to be 10.4. Got the stock rods reconditioned. He polished the crank himself with 600 paper. He got a Comp Cam and the heads from Brian at IMM. Its got an RPM air gap manifold on it and a 750 DP. The car runs very well and on pump gas too.
[Re: n20mstr]
#2843360
11/08/20 06:50 AM
11/08/20 06:50 AM
mopar65
Damn that's awesome. N20mstr can you give more info about your sons engine? Nothing crazy. a Magnum that we ballhoned. He got a flattop forged piston.(standard bore) We figure the comp to be 10.4. Got the stock rods reconditioned. He polished the crank himself with 600 paper. He got a Comp Cam and the heads from Brian at IMM. Its got an RPM air gap manifold on it and a 750 DP. The car runs very well and on pump gas too. Wow that is awesome. I am still tuning on mine but I have a 96 SB Dodge dakota sport I built into a por mans race truck. Lol I call it my Pro-Junk yard Dakota. Lol I have a 2000 360 magnum engine. It has a stock stroke stock rod, stock crank and stock bore, but does have KB107 pistions. A comp 550 solid lift cam. The heads are out of the box trick flow 190cc heads. PRW 1.6 ROLLER Rockers. Ported indy single plane intake. 800 holley DP carb. 904 transmission with a 8 inch 5600 stall coan converter 4.30 gears and 28x9x15 slicks. I think the compression came out to 11.1. All runs are on 93 pump gas I dont think the converter is working right. But my best pass has been 11.24 at 115 in the 1/4 and 7.15 at 95.90 in the 1/8 what did your sons car run in the 1/8? I think my truck weighed around 3400/3500 with me in it. I hope it will run in the 10 in the 1/4 with some torque converter tweaking. If I dont end up building a hen3 hemi for my dakota, I would like to build a 426+ stroker small block with around 13-14.1 compression and run it on E85.
support our troops
[Re: n20mstr]
#2844735
11/11/20 02:11 AM
11/11/20 02:11 AM
mopar65
mopar65 lighten it up a little. 3500 is heavy !! I am going to try.lol I have lost 30 pounds and am down to 275..the truck might not weigh 3500 pounds. I am just guessing.i am going to get it weighed this spring.
support our troops
