Massive Power Draw #283861
04/10/09 05:06 PM
04/10/09 05:06 PM
Athens, Greece
Pyper70 Offline OP
Pyper70  Offline OP
Athens, Greece
Everything is running fine but today I stopped for a brief moment and I left the parking lamps on my 69 Charger and I went to turn her on again and all I got was the bendix clicking like there wasn't enough juice in the battery. WEIRD!
Anyways, I understand that with parking lamps on I have plenty of voltage running through the lamps. 3 on each side in the rear and 2 front lamps, plus all the bulbs on the dash on as well. I also noticed that my left front turn signal in the valance was super dim compared to the right one, so I am thinking something came loose as she has never been like that before. So I have a bad ground on the left turn/signal light circuit...Would that be the root of a massive power draw and cause my starter bendix to not engage fully?
.....Shut off the parking lamps and she fired right up and continued on home, battery is charging at 14.5 volts...
I dunno....boggled
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Massive Power Draw [Re: Pyper70] #283862
04/10/09 05:28 PM
04/10/09 05:28 PM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
Sounds like a short to ground.
Better check the wires and see what is going on.
Re: Massive Power Draw [Re: SRT8Challenger] #283863
04/10/09 06:10 PM
04/10/09 06:10 PM
I would clean(or check) all (6) ends of your large battery cables plus the block to firewall one wouldn't hurt also but especially the battery posts/terminals.
Re: Massive Power Draw [Re: Pyper70] #283864
04/10/09 06:23 PM
04/10/09 06:23 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Before getting carried away check battery voltage and do a load test to see it is still strong.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Massive Power Draw [Re: HealthServices] #283865
04/10/09 07:28 PM
04/10/09 07:28 PM
Az
Crizila Offline
Crizila  Offline
Az
and check alternator output while your at it. Bad bulbs / light socket grounds won't cause your problem.
Fastest 300
Re: Massive Power Draw [Re: Crizila] #283866
04/11/09 04:30 PM
04/11/09 04:30 PM
COLLINGWOOD, ONT
71_deputy Offline
71_deputy  Offline
COLLINGWOOD, ONT
also check the grounds to block!
