Where to find R3 block #2838516
10/28/20 09:24 PM
10/28/20 09:24 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Trying go get parts together for small block build. I’m shooting for 600 n/a and adding nitrous. Or may do blower
It was suggested to me by my builder that I try to find an R3 block.
Your direction is appreciated !
Re: Where to find R3 block [Re: lostdog] #2838523
10/28/20 09:43 PM
10/28/20 09:43 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Think those were discontinued years ago along with a lot of other Mopar small block race parts. They show up for sale on Ebay occasionally. They made those in numerous deck heights, lifter angles, etc so you have to pay attention.
If you go to Hughes Engines website you can get a Ritter block that fills the R3 block void.
Re: Where to find R3 block [Re: lostdog] #2838525
10/28/20 09:44 PM
10/28/20 09:44 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Move this over to Unlawful's Race and Engine Tech and those guys will know. up
Re: Where to find R3 block [Re: lostdog] #2838527
10/28/20 09:50 PM
10/28/20 09:50 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Call Indy cylinder head
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Where to find R3 block [Re: lostdog] #2838529
10/28/20 10:00 PM
10/28/20 10:00 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thanks guys !
Re: Where to find R3 block [Re: lostdog] #2838562
10/28/20 11:14 PM
10/28/20 11:14 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Really depends on what you’re goals are.... been some pretty bad builds in the last year and a half using the newer Ritter block.
What Heads? 48 degree? 59 degree? The possibilities are vast
Re: Where to find R3 block [Re: lostdog] #2838567
10/28/20 11:28 PM
10/28/20 11:28 PM
AndyF Offline
AndyF  Offline
I used a Mopar 340 resto block a few years ago to build a 427. That was a very nice engine. It cost some bucks to build and it was heavy, but it sure hauled the mail.
Re: Where to find R3 block [Re: AndyF] #2838577
10/29/20 12:01 AM
10/29/20 12:01 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
All NS1 Andy..... no longer made frown
Re: Where to find R3 block [Re: J_BODY] #2838592
10/29/20 12:58 AM
10/29/20 12:58 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Has the Ritter block got the bugs worked out of it now?
Re: Where to find R3 block [Re: slantzilla] #2838664
10/29/20 09:47 AM
10/29/20 09:47 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
From what I hear the new blocks are good, but like any block should be checked out closely by a competent machine shop.
I have heard one report of a new block with a problem but I have not heard if Ritter made it right or not. Ritter was supposed to look at it.
Lots of reports of new blocks without issues that have made a ton of power.
Re: Where to find R3 block [Re: 340Cuda] #2838689
10/29/20 11:01 AM
10/29/20 11:01 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I find myself in a situation of asking for something I don't know anything about, which I try to avoid. But it looks like it's complicated with different deck heights, lifter angles, cooling and oiling is different - and I don't' know what else. I had no idea and was just thinking it was a stouter version of the LA. I'll take any advice I can get, but maybe a cross drilled main cap LA engine would work fine. I understand pay- to- play but at this stage in my life if it's too complicated I'll lose interest. This is not an engine I will beat on pass after pass at the track but maybe a few "street outlaw" kinda races but mostly it will be street driven and in a '70 Duster
Re: Where to find R3 block [Re: lostdog] #2838704
10/29/20 11:34 AM
10/29/20 11:34 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have an R1 block in my drag car (avatar) and it's much beefier around the crank than the stock 340/360.
I think the resto block has most of those features but is the production deck height & 59-degree arrangement.
Re: Where to find R3 block [Re: topside] #2838707
10/29/20 11:39 AM
10/29/20 11:39 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Do you know if the 340 restoration block is still available ? and where to get one
Re: Where to find R3 block [Re: lostdog] #2838708
10/29/20 11:43 AM
10/29/20 11:43 AM
AndyF Offline
AndyF  Offline
Aftermarket blocks for the SB Mopar is a complete minefield for the uninformed. You'll need to educate yourself and even then you might get stuck with a worthless block. For your application you should just find an early 360 block. Many of the early 360 blocks had extra thick cylinder walls. I sold a couple of early 360 blocks that were over 0.200 thick in the walls.
Re: Where to find R3 block [Re: AndyF] #2838715
10/29/20 11:52 AM
10/29/20 11:52 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I agree with you 100% ! My first inclination was to get an early 360 as you said but I haven't had much luck with that either.
Re: Where to find R3 block [Re: lostdog] #2838732
10/29/20 12:17 PM
10/29/20 12:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Even early blocks are a crap shoot. I used a 72 model 360 for my 408 street/strip build in my 69 Dart, it ran 6.57 @ 104 and change in the 1/8 on pump 93. After five years I pulled it to freshen it up, the cam bearings and main bearings showed signs of block flex. I lucked out and didn't bust a cylinder and ruin a bunch of parts. Luckily I found and bought a complete but apart Indy headed R1 block engine. IIRC the R1 is around 60# heavier than a production block.
Re: Where to find R3 block [Re: justinp61] #2838881
10/29/20 05:10 PM
10/29/20 05:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
600 hp on the motor with nitrous and or a blower on top of that? I think an aftermarket block would be better.
