nv3500 #2836835
10/24/20 08:57 AM
10/24/20 08:57 AM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
I am going to start looking for a nv3500hd to put in my polypowered sweptline. according to some of the rebuilder houses websites all the Dakota's had the hd version whereas the ram 1500&2500 had the regular one. Seems backward to me. Any insight on this? The Ram and Dakota take different shifter "bases" so there are some differences between the 2.
Re: nv3500 [Re: Handygun] #2836873
10/24/20 11:44 AM
10/24/20 11:44 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
The Dakota shifter is positioned further rearward.
As for the torque rating, yes, Dakota is 40 lb/ft higher rating, but I have never seen a reason why. You would think by now someone would know and give reason but I have yet to see it.
Dakota transmissions are easier to find, usually had V6's in front of them which should equal less wear and tear than the V8's.
Sounds like a neat project. up
Mo' Farts
Moderated by "tbagger".
Re: nv3500 [Re: Handygun] #2836896
10/24/20 12:35 PM
10/24/20 12:35 PM
Guitar Jones Offline
I don't think you will find an NV3500 in a 2500 Ram, at least not with a V8 and maybe that is why. Perhaps all the 1500s are V6 and/or light duty short bed single cabs, I don't really know though, just speculation.
Re: nv3500 [Re: Guitar Jones] #2837146
10/25/20 01:39 AM
10/25/20 01:39 AM
Salem
Grizzly Offline
Grizzly  Offline
Salem
Yep, Guitar NV3500's are in the 2500's, with 360 Magnum. They are rare to come by; I've seen maybe 2 for sale in the last 3, 4 years or so in my area.
Makes no sense why they would have the 360 5 speed for the 2500 and not the 1500? Power isn't the issue, the NV3500 was used with 350's
Mo' Farts
Re: nv3500 [Re: Grizzly] #2837170
10/25/20 06:11 AM
10/25/20 06:11 AM
Everyone I've ever seen was a NV4500 and those are rare. I got my NV4500 out of a 1997, 2500, 5.9 Magnum truck.
Re: nv3500 [Re: Guitar Jones] #2837402
10/25/20 09:03 PM
10/25/20 09:03 PM
STL ,MO
Handygun Offline OP
Handygun  Offline OP
STL ,MO
Thanks for the replies. Got a line on a 6 cyl Dak w/5speed for parts now.The Poly has a 4" crank, ported big valve heads etc and doesn't get along with the old 745 too well, these extra gears should help.
