Clean Netural Valve Body necessary when running alum rods? #2837044
10/24/20 07:02 PM
10/24/20 07:02 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
I have a brand new set of Childs and Albert Pistons and Aluminum rods to build a stock stroke 20 over 440.
I was wondering if a clean neutral valve body would be necessary to run these at the track?
Re: Clean Netural Valve Body necessary when running alum rods? [Re: domingo] #2837115
10/24/20 10:39 PM
10/24/20 10:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I never did. Put 300 passes on them with 4.5 stroke over 7000 rpm.
Doug
Re: Clean Netural Valve Body necessary when running alum rods? [Re: dvw] #2837206
10/25/20 10:05 AM
10/25/20 10:05 AM
Penna
70satelliteguy Offline
Penna
"I never did. Put 300 passes on them with 4.5 stroke over 7000 rpm."
Doug
Me neither. 7K with BME aluminum rods
Mike
