Motor plate custom?
#2837010
10/24/20 06:03 PM
10/24/20 06:03 PM
Posts: 63 Wisconsin
1964maxwedge
Wisconsin
I'm looking for a lower profile motor plate one piece, or someone making a custom one. . It's for 1964 b body with a wedge.
Re: Motor plate custom?
[Re: 1964maxwedge]
#2837060
10/24/20 07:38 PM
10/24/20 07:38 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Have you look at the AR engineering plates that AndyF on here makes and sells? If not maybe you should see if they will work for you I've used one to install a 426 Blown gas street Hemi motor in a 1971 Cuda so I could locate the motor to clear both valve covers.
[Re: 1964maxwedge]
#2837210
10/25/20 10:17 AM
10/25/20 10:17 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I'm looking for a lower profile motor plate one piece, or someone making a custom one. . It's for 1964 b body with a wedge. Arch Engineering Integration 5753 Westwood Drive Saint Charles, Missouri 63304 By phone: (314)435-3461 or (636)875-0666 info@ http://www.aeicnc.com/http://www.aeicnc.com/Bob Ette, he did some stuff for me several years ago and he was good to work with.
[Re: Dragula]
#2837484
10/26/20 08:28 AM
10/26/20 08:28 AM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
I always buy the S&W full plates and cut them down to what I need... Why not just buy a cheap one piece plate, fit it to the car, and then trim off what you don't want?
[Re: Dragula]
#2837530
10/26/20 12:09 PM
10/26/20 12:09 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
I always buy the S&W full plates and cut them down to what I need... x2
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
