Re: Exhaust Manifold Heat Riser Operation
[Re: NITROUSN]
#2835988
10/22/20 09:38 AM
10/22/20 09:38 AM
Posts: 10,752 North Dakota
6PakBee
North Dakota
It will be closed all the time without the engine running. The spring heats up and lessens the tension when running. Either the stop is missing or it is assembled incorrect. Agreed. If correctly assembled, the valve should be closed. If you open it by hand, the spring will close it.
[Re: vinnyd76]
#2836151
10/22/20 03:41 PM
10/22/20 03:41 PM
6PakBee
North Dakota
This is what I would use. Mopar Rust Penetrant
[Re: 70Xman]
#2836173
10/22/20 04:26 PM
10/22/20 04:26 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Somebody probably purposefully installed the spring backwards to avoid the clanking of the valve at idle.
[Re: NITROUSN]
#2836298
10/22/20 09:51 PM
10/22/20 09:51 PM
Posts: 38 Pennsylvania
70Xman
Pennsylvania
It will be closed all the time without the engine running. The spring heats up and lessens the tension when running. Either the stop is missing or it is assembled incorrect. After looking at it further, I think you are correct in that the stop is missing. The stop should hold the plate in the closed position when cold, and the spring when heated, will open the plate 90 degrees. What is happening now is that the spring allows the plate to move 180 degrees, back to the open position. Thanks for your input. Now I just have to figure out what it is that should be stopping it in the closed position.
[Re: 70Xman]
#2836311
10/22/20 10:17 PM
10/22/20 10:17 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
It will be closed all the time without the engine running. The spring heats up and lessens the tension when running. Either the stop is missing or it is assembled incorrect. After looking at it further, I think you are correct in that the stop is missing. The stop should hold the plate in the closed position when cold, and the spring when heated, will open the plate 90 degrees. What is happening now is that the spring allows the plate to move 180 degrees, back to the open position. Thanks for your input. Now I just have to figure out what it is that should be stopping it in the closed position. There was a stop pin that had to be there before assembley of the riser. I think if you research pictures you will see the pin that's needed. Does the manifold have the stamped steel counter weight or the round cast counter weight? There is a difference on how they look?
[Re: NITROUSN]
#2837039
10/24/20 06:54 PM
10/24/20 06:54 PM
70Xman
Pennsylvania
It will be closed all the time without the engine running. The spring heats up and lessens the tension when running. Either the stop is missing or it is assembled incorrect. After looking at it further, I think you are correct in that the stop is missing. The stop should hold the plate in the closed position when cold, and the spring when heated, will open the plate 90 degrees. What is happening now is that the spring allows the plate to move 180 degrees, back to the open position. Thanks for your input. Now I just have to figure out what it is that should be stopping it in the closed position. There was a stop pin that had to be there before assembley of the riser. I think if you research pictures you will see the pin that's needed. Does the manifold have the stamped steel counter weight or the round cast counter weight? There is a difference on how they look? Mine has the heavy round counter weight. I looked everywhere for a stop pin where one should be, but found no sign of one. I was thinking of drilling a hole on the counter weight and putting in a roll pin that would stop the assembly from going past the closed position. I simulated this buy sticking a small open end wrench inside the exhaust hole that held the plate in the closed position and heated up the weight and bi metal spring and it worked perfectly. It allowed the plate to be moved to full open at around 300 degrees. And as it cooled, it was fully closed again at around 200 degrees. I don't know how to find any pictures of where the factory pin should be. If you know of any, please post or send a link. Thanks!
[Re: 70Xman]
#2837092
10/24/20 09:17 PM
10/24/20 09:17 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
It will be closed all the time without the engine running. The spring heats up and lessens the tension when running. Either the stop is missing or it is assembled incorrect. After looking at it further, I think you are correct in that the stop is missing. The stop should hold the plate in the closed position when cold, and the spring when heated, will open the plate 90 degrees. What is happening now is that the spring allows the plate to move 180 degrees, back to the open position. Thanks for your input. Now I just have to figure out what it is that should be stopping it in the closed position. There was a stop pin that had to be there before assembley of the riser. I think if you research pictures you will see the pin that's needed. Does the manifold have the stamped steel counter weight or the round cast counter weight? There is a difference on how they look? Mine has the heavy round counter weight. I looked everywhere for a stop pin where one should be, but found no sign of one. I was thinking of drilling a hole on the counter weight and putting in a roll pin that would stop the assembly from going past the closed position. I simulated this buy sticking a small open end wrench inside the exhaust hole that held the plate in the closed position and heated up the weight and bi metal spring and it worked perfectly. It allowed the plate to be moved to full open at around 300 degrees. And as it cooled, it was fully closed again at around 200 degrees. I don't know how to find any pictures of where the factory pin should be. If you know of any, please post or send a link. Thanks! The pin is pressed into the manifold,probably broken or rusted off,look close and you'll find it.
[Re: 62maxwgn]
#2837214
10/25/20 10:40 AM
10/25/20 10:40 AM
6PakBee
North Dakota
It should look something like this.
[Re: 6PakBee]
#2837727
10/26/20 07:54 PM
10/26/20 07:54 PM
70Xman
Pennsylvania
Yes, exactly like that. I think I know what is missing. A spring steel piece that goes in next to the bi-metal spring that limits the travel of the plate. I have a picture but I can't figure out how to post it.
[Re: 70Xman]
#2837744
10/26/20 08:26 PM
10/26/20 08:26 PM
NITROUSN
Yes, exactly like that. I think I know what is missing. A spring steel piece that goes in next to the bi-metal spring that limits the travel of the plate. I have a picture but I can't figure out how to post it. That is what contacts the pin. You might be able to replace it without removing the weight. If not you might be able to devise a puller to pull the weight off the shaft. Most likely it may be best to buy a kit and rebuild it.
