Re: Best ready to run distributor
[Re: modelmakerinc]
#2835686
10/21/20 03:27 PM
10/21/20 03:27 PM
Posts: 31,074 Oregon
AndyF
Hey all, just wondering there is a consensus on a ready to run distributor for a very stock 318 auto in a 1927 hot rod. Looking for minimal wiring, all in one style distributor
I am using Holley Sniper F.I. so I would like to go with a great ignition
Thanks in advance. Henry If you have the Sniper then you should install the matching Hyperspark. The Hyperspark will allow you to control timing from the Sniper. That gives you a fully integrated system. You can trigger a CD box from the Sniper. Holley sells a CD box and matching coil or you can use an existing MSD box. The Sniper has a white wire on it which connects to the CD box and provides a points signal.
