Re: indy cylinder valve covers
[Re: 70moparmike]
#2835574
10/21/20 12:15 PM
10/21/20 12:15 PM
Posts: 10,032 MN
JERICOGTX
MN
Mike I welded baffles into my INDY valve covers, and then have the Moroso screw in breathers. As for changing oil? use a funnel when you adjust valves, and have the covers off.
69 GTX
68 Road Runner
[Re: AndyF]
#2835636
10/21/20 01:39 PM
10/21/20 01:39 PM
Posts: 10,032 MN
JERICOGTX
MN
Andy, mine are drilled and tapped for the Moroso breathers. I do not run the nut that Moroso sends with, and can turn them out. The breathers have a O ring to seal them up.
69 GTX
68 Road Runner
[Re: 70moparmike]
#2835649
10/21/20 02:01 PM
10/21/20 02:01 PM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
Pardon my dust, I have the front sheetmetal off for bodywork and the shop is pretty dusty right now. I just used OE 1970 style breathers, stock Mopar grommets and Bolted in homemade baffles. Button head screws would have worked better but this is functional. You can weld in the baffles for a cleaner appearance.
I wasn't sure I would like this, but it has been fine for years. I started out with a breather puke tank and hoses which also worked but I got tired of the clutter + there was never any oil in the tank so it clearly didn't need any of that.
Rich H.
Esse Quam Videri
[Re: cl440]
#2835702
10/21/20 04:08 PM
10/21/20 04:08 PM
Posts: 860 lancaster,california
johnnycuda
I had baffled tubes welded on to each valve cover for a clamp style breather, welded a #20 AN male fitting onto the front section valley plate with a AN cap to pour the oil in.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
[Re: JERICOGTX]
#2835791
10/21/20 07:12 PM
10/21/20 07:12 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Mike I welded baffles into my INDY valve covers, and then have the Moroso screw in breathers. As for changing oil? use a funnel when you adjust valves, and have the covers off. That car is so sick. Jeff, what brand of paint did you use on the engine. My last batch of VHT did not seem be as green as previous batches
[Re: ZIPPY]
#2835795
10/21/20 07:15 PM
10/21/20 07:15 PM
Jeremiah
Rogue River, OR
I wasn't sure I would like this, but it has been fine for years. I started out with a breather puke tank and hoses which also worked but I got tired of the clutter + there was never any oil in the tank so it clearly didn't need any of that. I have never seen the roll pin retainer on a steering coupler. Is that a factory part? Sorry for hijack!
[Re: Jeremiah]
#2835799
10/21/20 07:26 PM
10/21/20 07:26 PM
Posts: 10,032 MN
JERICOGTX
MN
Mike I welded baffles into my INDY valve covers, and then have the Moroso screw in breathers. As for changing oil? use a funnel when you adjust valves, and have the covers off. That car is so sick. Jeff, what brand of paint did you use on the engine. My last batch of VHT did not seem be as green as previous batches Dupli-color DE1619. You can get it at OReilly’s
69 GTX
68 Road Runner
[Re: Jeremiah]
#2835956
10/22/20 07:42 AM
10/22/20 07:42 AM
ZIPPY
S.E. Michigan
I wasn't sure I would like this, but it has been fine for years. I started out with a breather puke tank and hoses which also worked but I got tired of the clutter + there was never any oil in the tank so it clearly didn't need any of that. I have never seen the roll pin retainer on a steering coupler. Is that a factory part? Sorry for hijack! Yes, it is a factory type repair part that I believe originated from a TSB. It holds the stamped steel part on the back of the coupler more securely. Over the last 30 years or so two sources that I know of in Metro Detroit have sold them. Mike Randall had them for many years, but when he ran out Jim Fillmore started selling them. I got this one from Jim.
Rich H.
Esse Quam Videri
[Re: 70moparmike]
#2835957
10/22/20 08:10 AM
10/22/20 08:10 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
thanks for all the pics. i like the stud welded in pic the best, did you have any clearance problems with the roller rockers? thanks Are you referring to mine with the threaded standoffs welded in?
[Re: mopar dave]
#2835961
10/22/20 08:14 AM
10/22/20 08:14 AM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
I use a rubber grommit on the driver side with a pushin style breather on a tube extended a couple inches above the valve cover. I have a filter sock on the pushin breather. On the pass side i have a -12 hose connected to valve cover with AN fittings. I now get 0 oil leaks on top of my motor. Before this, after a spirted drive i would have oil running out valve covers and all over the valley tray. You need a way to vent the crankcase pressure and this set up works. Next option would have been a vacuum pump. No baffles in covers and rattle can caliper paint.
[Re: mopar dave]
#2835987
10/22/20 09:37 AM
10/22/20 09:37 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I welded a pair of male -10 AN fittings onto mine.
[Re: an8sec70cuda]
#2835989
10/22/20 09:39 AM
10/22/20 09:39 AM
an8sec70cuda
On the hemi I welded in a -12 male fitting on the driver's side cover for the vacuum pump. Passenger's side got a welded in fill cap.
[Re: cl440]
#2836067
10/22/20 12:36 PM
10/22/20 12:36 PM
Posts: 294 indy
70moparmike
indy
