Need measurement for e body drive shaft please
#2834771
10/19/20 08:21 PM
10/19/20 08:21 PM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
I have a driveshaft out of a 70s dodge truck(no slip yoke) I want to cut down to fit 70 cuda. 8 3/4 727 trans I know measurements are from center of cap to center of cap. Just don't know what they should be Thanks in advance
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: Need measurement for e body drive shaft please
[Re: toplescuda]
#2834910
10/20/20 09:04 AM
10/20/20 09:04 AM
Posts: 2,252 New York
rarefish
New York
I have a driveshaft out of a 70s dodge truck(no slip yoke) I want to cut down to fit 70 cuda. 8 3/4 727 trans I know measurements are from center of cap to center of cap. Just don't know what they should be Thanks in advance With a small block the shaft would be: 47.95" long With a 383-4, 426 and 440 the shaft would be 43.60" long
[Re: rarefish]
#2834920
10/20/20 09:42 AM
10/20/20 09:42 AM
Posts: 259 n.c.
geo.
n.c.
I have a driveshaft out of a 70s dodge truck(no slip yoke) I want to cut down to fit 70 cuda. 8 3/4 727 trans I know measurements are from center of cap to center of cap. Just don't know what they should be Thanks in advance With a small block the shaft would be: 47.95" long With a 383-4, 426 and 440 the shaft would be 43.60" long I beg to differ, if 727, all the same length. Now 904 IS different.
[Re: geo.]
#2834936
10/20/20 10:21 AM
10/20/20 10:21 AM
RapidRobert
take the shaft & butt it all the way in the trans then measure the C to C then subtract 3/4". that is your #. there are too many variables to go by a set # especially since you are having the shaft cut you might as well get it dead on perfect. have the rear end/springs loaded.
[Re: rarefish]
#2835304
10/20/20 09:14 PM
10/20/20 09:14 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
I have a driveshaft out of a 70s dodge truck(no slip yoke) I want to cut down to fit 70 cuda. 8 3/4 727 trans I know measurements are from center of cap to center of cap. Just don't know what they should be Thanks in advance With a small block the shaft would be: 47.95" long With a 383-4, 426 and 440 the shaft would be 43.60" long Is This measurement from center of cap to center of cap?
[Re: toplescuda]
#2835415
10/21/20 04:32 AM
10/21/20 04:32 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I have a driveshaft out of a 70s dodge truck(no slip yoke) I want to cut down to fit 70 cuda. 8 3/4 727 trans I know measurements are from center of cap to center of cap. Just don't know what they should be Thanks in advance Fortunately I just happen to have the driveshaft for my Bblk /727/8 3/4 1970 Cuda out, the measurement is: center to center on the U joint caps 43.625 inches/ 43 5/8 inches As mentioned earlier in this thread, it'll be the same measurement for any 727 TF equipped 8 3/4 Cuda smblk or Bblk Mike
