Jeep GC front axle turned it's self into a locker. #2832251
10/13/20 11:24 AM
10/13/20 11:24 AM
A certified culture free zone.
74RALLYE Offline OP
74RALLYE  Offline OP
My father has a 94 Jeep GC and blew a tire in another state. He had a tire put on that wasn't the exact same size as the other. After a few months the front diff. started acting like a locked differential. Low speed turning on pavement is ugly. Any ideas about what I should look for when I open it up?
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832263
10/13/20 12:03 PM
10/13/20 12:03 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I don't think you will have any problem seeing what went wrong when you open it up.
Re: Jeep GC front axle turned it's self into a locker. [Re: stumpy] #2832287
10/13/20 01:14 PM
10/13/20 01:14 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Would burned up spider gears be the only thing that would cause the axle to act like a locker? I was guessing that someone else had seen what happens from a wrong size tire and if they were able to fix it without replacing the diff.
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832319
10/13/20 02:13 PM
10/13/20 02:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You most likely will get away with rebuilding the one you have. Dr diff could give you a better answer.
Re: Jeep GC front axle turned it's self into a locker. [Re: stumpy] #2832366
10/13/20 04:29 PM
10/13/20 04:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
What transfer case? My bets the viscous coupler is bad.
Re: Jeep GC front axle turned it's self into a locker. [Re: NITROUSN] #2832392
10/13/20 05:33 PM
10/13/20 05:33 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
This
68 Barracuda Formula S 340
Re: Jeep GC front axle turned it's self into a locker. [Re: Bad340fish] #2832415
10/13/20 06:36 PM
10/13/20 06:36 PM
74RALLYE Offline OP
74RALLYE  Offline OP
I don't know which transfer case it has other than stock.
I get it, like leaving my manual trans truck in 4WD on pavement.
How would I test it's coupling?
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832451
10/13/20 08:27 PM
10/13/20 08:27 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Take the time to identify what case you have first. On the case there is a round tag that will have the model number stamped on it.
Re: Jeep GC front axle turned it's self into a locker. [Re: NITROUSN] #2832722
10/14/20 01:55 PM
10/14/20 01:55 PM
74RALLYE Offline OP
74RALLYE  Offline OP
The transfer case is a NP 249 J. I also picked up the 1994 factory service manual today!
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832731
10/14/20 02:11 PM
10/14/20 02:11 PM
74RALLYE Offline OP
74RALLYE  Offline OP
Here's a pic of the tag. It's a 249 case. I just noticed some yellow paint in the corner of the pic. Might be a junk yard swap from the previous owner.
How can I test the viscous coupling? It looks like a $500 part so swapping the whole thing will be cheaper if that's the problem.
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832750
10/14/20 03:08 PM
10/14/20 03:08 PM
Kirkland, Washington
Pacnorthcuda Offline
We need Scott Smith to ID that cocoon thing.
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2832770
10/14/20 04:24 PM
10/14/20 04:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
There is no real test that I am aware of that conclusively pinpoints it to the viscous coupler. For the most part it is the symptoms. The hotter it gets the worse it gets. Binding on turns especially if you drive in figure 8's at a parking lot. The tires will bind and chirp. Depending on miles a used one may not be much better. For sure these type transfer cases need 4 tires identical in make and size.
Re: Jeep GC front axle turned it's self into a locker. [Re: Pacnorthcuda] #2833024
10/15/20 01:16 PM
10/15/20 01:16 PM
moparx Online content
moparx  Online Content
kinda looks like a mud wasp nest.
beer
Re: Jeep GC front axle turned it's self into a locker. [Re: moparx] #2833320
10/16/20 09:31 AM
10/16/20 09:31 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
You can pull the front shaft, if that fixes the problem then you can count on it being the t-case.
I don't think its good for them but they can be driven without the front shaft. I know when I used to follow the jeep stuff closer the 5.9L grand Cherokee guys would do this so they could do burnouts lol.
Re: Jeep GC front axle turned it's self into a locker. [Re: Bad340fish] #2833779
10/17/20 09:38 AM
10/17/20 09:38 AM
74RALLYE Offline OP
74RALLYE  Offline OP
Thanks everyone. I was thinking it was the diff. and hadn't considered the transfer case. A trip to the junkyard is in order.
Re: Jeep GC front axle turned it's self into a locker. [Re: 74RALLYE] #2833826
10/17/20 11:53 AM
10/17/20 11:53 AM
Alberta
440_Offroader Offline
Alberta
I guess you could always pull the rear driveshaft and see if it still does it. If it still does it, it would be the front end. Easier yet, just jack up the front and try rotating one wheel. The other side should rotate in the opposite direction pretty easy.
