OK, so I have the axle bolted in. It has a 318 with the OD auto trans. Motor not running, front tires off the ground, it sure feels like its binding real bad at both extremes of turning the wheels. When you reach the last 1/4 turn of the steering wheel (in either direction), the tires want to rotate in opposite directions. With the tires on the ground and weight there, you almost can't turn it. I suspect the power steering would help, but is this pretty normal with a cad axle or is there a problem I need to look for? Gene
